Question about Singer 7442 Mechanical Sewing Machine
Singer 7442 Timing
Machine sews fine in a straight line but it appears to not be picking up thread to the left of the centre.
It has recently jammed a couple of time as my partner didn't properly read the instruction manual before use... even though i told her to, as she had another machine befreo she was fairly confident... anyhow, either thread quality, tension or something made it Jam and when i called singer he said I may have to bring it in.
Under 5 years Warrantee so it is for free.
But to save hassle I am wondering if there is a way I am able to correct the timing myself?
Phew,
Cheers guys,
James
Rahul Sudhan
  • 30 Answers
SOURCE: How do I fix a
Here's how you set the timing od the Machine alright:
1. Take the side plate off, take the needle plate off.
2. Take the presser foot off, and put a new needle in the machine. 3. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
4. Then, turn the handwheel toward you until the top line is where the bottom line was.
At this point, the tip of the hook should be directly in the scarf of the needle.
This should set the timing of the machine perfect....
Posted on Jan 05, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
  • 3 Answers
SOURCE: Singer 7442 How to get inside ?
http://www.scribd.com/doc/3713782/Singer-7442-Sewing-Machine-Manual heres your manual, good luck!
Posted on May 13, 2009
bargainbox
  • 1388 Answers
SOURCE: singer 7426 timing off
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Posted on Aug 27, 2009
Testimonial: "very helpful...thank you"
  • 33 Answers
SOURCE: Singer 7442, how do I adjust the timing?
Have you changed your needle? What needles are you
using?Other than that it may be that your needle may be
too high and not in the right position. So I would
play with maybe bringing it down a little bit at a time -
and hand turn your wheel.
Posted on Feb 12, 2010
I have a singer model 7442. It won't pick up the bobbin thead
Try installing a brand new needle. If it still will not pick up the bobbin thread, most likely the machine is out of time. Search for sewing machine timing or take it for service.
Jan 28, 2017 | Singer Sewing Machines
Singer 7442 won't stitch at all. It picks up the bobbin thread nicely, but after that won't stitch at all. Any suggestions?
Sound like one or the other of the threads is stuck. Completely un- thread your machine and remove the bobbin. See if the needle moves freely with the machine unthreaded. If it does, carefully rethread the machine and reinsert the bobbin, making sure the bobbin thread is feeding the correct direction. Let us know what happens.
Oct 23, 2016 | Singer 7442 Mechanical Sewing Machine
My bobbing thread is looping on all types of stitching. Machine was working fine. Cleaned all reachable components as per manual.
Most of the time it is in your top threading or a bad needle. Try this and if it doesn't work call Singer at 1-800-4singer. I am hoping that it is not the timing. Good luck
Oct 05, 2010 | Singer 7442 Mechanical Sewing Machine
My Singer Advance 7422 skips stitches intermittently. Looks like it does not pick up the bobbin thread sometimes. Any suggestions?
Change to a new needle appropriate for the fabric you will be sewing. Make sure the flat side of the needle shank faces to the back of the sewing machine.
Always thread the machine with the presser foot up as this will "seat" the thread into the tension control.
Mar 17, 2010 | Singer 7442 Mechanical Sewing Machine
I can't get it to pick up the bobbin thread??
Check the needle to be sure it is installed with the flat side of the shaft toward the back of the machine.
If the needle is properly installed and not bent, then there is a possibility that that machine will have to go into the shop for a timing adjustment.
Mar 14, 2010 | Singer 7442 Mechanical Sewing Machine
Feb 12, 2010 | Singer Quantum 9920 Computerized Sewing...
Thread from the needle does not go around the
needs retime, need singer servcie person for this, very hard to even open the cover to get to the timing
Sep 26, 2009 | Singer 7442 Mechanical Sewing Machine
Sewing machine timing problem
Singer sewing machine needle does not go directly down into opening of foot, it hits the back plate of foot. how can i align it.
Apr 23, 2009 | Singer 14SH654
Singer 7442 will not sew
Had the same problem as mommyb2 - it was the bobbin spindel was in the wrong position. Push bobbin spindel to the left and it works for sewing.
Have the same problem winding my first bobbin - pushed spindel to the right to engage bobbin fuction and the machine locks up and wont wind the bobbin. Irig did you bring it in for repair? I'm thinking its broke - which **** as mine is a brand new machine
Mar 23, 2008 | Singer 7442 Mechanical Sewing Machine
Singer 7442 Mechanical Sewing Machine Logo
124 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
