Hi there. To enable your Samsung DVD player to work on your Sony Plasma, you will need two things:
1. The Power cable for the DVD player 2. The Audio(Red and White) and Video(Yellow) cables that should have been provided when the DVD player was bought. If ever these cables are not available, you may buy these at any Hyper Market such as Wal-Mart or a technology store such as Best Buy. These are called Composite Video and Audio Cables.
If you have the previous cables, connect the 3 Audio/Video cables to the back of the Plasma TV, it should contain the appropriate ports. Yellow cable(Video) for the Yellow port. White and Red for the Audio Left(L) and Right(R) ports. Then connect your power, turn the DVD on and switch from TV to other input which should display the Samsung Logo.
How do u hooking up this thing,up by a AV component video RYW signal cable to an analog tv,a LCD,plasma tvs or an a HDMI cable to a LCD or a plasma tvs?More informations please?
No,u can use the R,Y,W colors AV cable,the same hook up as a VCR recorder in the past.Read ur instructional manual,find out, if the unit can take HD hook up,use a HDMI cable for the hook up.Yes,buy a HDMI cable hook up to ur LCD or Plasma tv.Best result and the use of the recorder and LCD or Plasma digital tvs.
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
if you connect composit video from your DVD player to the "Y" jack of the tv then you will get only a black and white picture .. the composit video out of your DVD has to be connected to the composit video input of the TV .. or if you have component outputs on your DVD then you can hook those up to the "three" component inputs of the tv .. (you have to have all three hooked up plus 2 audio cables ..
Actually if you do have a ps2 you don`t really need a Dvd upconverter because Ps3 is a full Dvd player +blu Ray Hi Definition.I suggest to take the dvd out and just use the ps3 as a Dvd player
Good Luck
may have to change rca cables or s-video cables, or maybe try a new reciever, or maybe goin from dvd player straight to the plasma? hope this helps jason
