Question about Whirlpool AWM5104/1 Front Load Washer
Whirlpool washing machine Model AWM 5104/5
The soap dispenser in my washing machine does not release the soap powder and becomes blocked. Any ideas?
  • bardotfilms Feb 28, 2008
    Thank you for your help. Sadly it did not solve the problem and the engineer fitted a new dispenser box as it had warped and the gate did not open properly.
    Many thanks
The despencer has a motor on it are a water valve that puts the water into the right despencer at the right time to make it work look under the top if its a water valve type needs new valve
Posted on Feb 25, 2008
Water coming out soap dispenser
If you use powder, check the delivery tube is not blocked with any undissolved powder. The same goes for the drain tube and eventually the drain getting blocked. I now use liquid soap because of this.
Sep 03, 2015 | Whirlpool duet Washing Machines
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Water leaking out of soap dispenser?
Mar 17, 2013 | Washing Machines
Simpson front loader washer leaking from front soap drawer on the spin and rinse cycle when filling
Mar 10, 2013 | Washing Machines
AWM5104/1 Front Load Washer: Whirlpool AWM 5104 - The machine turns on and the ...
May be the belt at the back of the machine is loosen or cut off kindly check it and replace the belt
May 06, 2010 | Whirlpool AWM5104/1 Front Load Washer
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Soap block not releasing while washing
I urge you to only use Electrosol or Cascade powder with your (or any) dishwasher. Most ultra-cheap powder will not clean effectivly. If the dispenser does not open with the powder inside, a service call is the next step.
If you reply, please tell me the Make and model of your dishwasher.Good Luck!
Mar 23, 2009 | LG Dishwashers
Fabric softener not dispensing
Fabric softner trays often clog up, because a little soap powder in the tray by accident tends to block it. If you pull the soap tray out as far as it will go, you will see that there is a bit of the tray right at the back, probably on the left with an arrow or thumb print or indentation in it. If you press down on this it is a catch and it will allow you to remove the tray from the machine completely. Once out of the machine, the fabric softner cover will also lift out. Clean everything throroughly (Tak it outside and turn your garden hose full pressure on all the holes on the tray and then scrub it out with a toothbrush. Put the fabric softner tray mabc in and slide the soap tray back in the machine. This should have fixed it.
Mar 01, 2009 | Whirlpool Washing Machines
Whirlpool AWM5104/1 Front Load Washer Logo
216 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
