Back to:
Tags:
VCRs
Generic problem for all VCRs
VCR won't run.
posted by Unclecracker on Feb 25, 2008
Hello, have a JVE TV/VCR combo that the TV works great. The VCR will accept a tape and eject it fine but won't run it for playback. It will jog the tape a little when you push the FF & REW buttons but that is all. I also don't have a remote for this TV and don't know if not being able to access the menue would have any thing to do with it. Do you have any sauggestions on what I might do? Thanks!!!!!!!
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 25, 2008
Not Rated (0)
Benimur
Rank:Guru Guru
Rating: 87%, 2403 votes
Based on your description, I would suspect that the tape is not fully engaging/wrapping itself around the video head. This is a common issue with VCRs. This is caused by a slipping belt that drives the gears for the spreader arms. The belt is normally located top right of the mechanism/assembly and can be anywhere between 3-4 cm. You need to open the unit, remove the belt and purchase a replacement. The slipping belt would serve "as per sample".
This of course would require that you be a bit familiar with electromechanical components, a bit of electronics and use of common tools. Considering that it might be a bit tricky being a combo unit, perhaps seeking the services of a qualified professional would be your safest bet.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on VCR won't run.:
I don't want to Accept this solution
Can you Help with these VCRs problems?
Mitsubishi HS-U580 VHS VCR
I have a Mitsubishi HS-U580 VHS VCR and don't have a...
Sharp VC-A560U VHS VCR
How do I change the recording speed from SP to SLP. HELP!
Rio Go Video GV6060 Dual Deck VCR
Deck seems to be fine but will not mrespond to remote...
Sharp XA-705 VHS VCR
hi i have vcr model no. vc-h705x which has been key locked...
Tape door will not open.
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
