Question about i-mate JAQ Pocket PC
Internet sharing I have win xp on my PC and I have an I-mate Jaq .... How do I share my PC's internet connection with my Jaq using Bluetooth.
  • Anonymous Apr 29, 2008
    u need to get activated GPRS/EDGE service from ur service provider. do following
    install latest version of activesync to ur PC
    after that active sync shud detect ur phone when connected thru USB
    disable any internet connection which is running apart from ur phone
    go to start-programs-internet sharing on ur phone
    pc connection shud be USB and network connection shud be ur isp and tab connect
    after that connect the phone to ur pc via usb and ur windows xp will recognise it as modem
    >>>babamanan@gmail.com
    Comment by babamanan, posted on Feb 21, 2008
    also pls note that u have sufficient service activated on ur mobile to access internet on a PC, I believe there are few services commonly for mobile internet
    1-WAP
    2-MMS
    3-WEB/GPRS/EDGE
    u need to select ur web service which will have full access to internet on phone or PC.
    also do following
    go to-settings-connections-connections-advanced-select networks
    therre will be 2 options
    1-programs that automatically connect to the internet should using : it should be ur web/gprs/edge
    2.programs that automatically connect to a private network should using : it should be ur web/gprs/edge
    make sure both for options the the ISP will be the same
I have I mate spl I want driver for cable modem
Posted on Feb 25, 2008
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
May 14, 2011 | Cell Phones
Tip
Set-up your I-mate Jama 101 into a Wireless Modem
Your i-mate™ JAMA 101 can be configured to act as a modem for your PC, allowing you to have a connection to the internet for your PC while you are out of the office or away from home. Your PC can be connected to your i-mate using Bluetooth® or a USB cable.
Although setting the device up for Internet sharing the first time may take some minutes, you only need to do these actions once per PC. Subsequent connections are quick and are explained at the end of each configuration.
Before you start, you must ensure ActiveSync 4.2 or later version is installed on your PC. You can find this program on the Getting Started CD that came with your device. You cannot run this function with earlier versions of ActiveSync. These instructions show how to set up your PC for connection over GPRS, please contact the customer support team if you wish to connect over a circuit switched connection. If you are running Windows Vista on your computer, you do not need to install Activesync. Windows Mobile Device Center software comes pre-installed with your operating system.
Getting Started
1. On your i-mate go to Start > Programs > Internet Sharing
2. You will be presented with the main screen of the Internet Sharing program
You now need to define the Web connection that your device will use to access the internet. If you have already defined an internet access connection in your device, you may select it from the dropdown menu in the ‘Network Connection’ list, and you are ready to connect to the internet. You can go straight to the section ‘Connecting over USB’ or ‘Connecting over Bluetooth’. If you have not yet defined an internet connection, you must define it now.
3. To set up the connection from inside Internet Sharing, go to Menu > Connection Settings
If your cellular subscription includes a GPRS subscription to the internet, then choose the GPRS option. In the bottom right, click “Next”.
4. Now fill in the details for your cellular provider’s access to the internet. You should contact your cellular provider for these details.
For the description field, you can type in any name you wish. For the “Connects To” field, choose “The Internet”. The “Access Point Name” field must be filled in with the details provided by your network operator.
Also enter the user name and password provided by your mobile operator, and any other details they provide, such as Primary DNS, Secondary DNS and IP address. If your mobile operator does not provide these to you, then leave the fields blank.
Once complete, press Done, then Done on the next page, and then Done on the next page to return you to the Internet Sharing application.
on Mar 30, 2009 | i-mate Jama 101 Smartphone
I need to use this phone as a modem for internet. How?
  • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
  • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
  • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
  • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
  • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Feb 04, 2011 | Samsung SGHE250i Cell Phone
Modem drivers for imate Jaq
I have i-mate JAQ. I want modem drivers of JAQ for xp operating system.
Could you please tell me the path or the link.
Thanks in advance.....
Jul 19, 2008 | i-mate JAQ Pocket PC
Too many connections win xp
In Windows XP Professional the maximum is 10, but you can set this to a lower value. You can use the Shared Folders snap-in to determine the maximum number of users that are permitted to access a folder. In the Shared Folders details pane, click the shared folder for which you want to determine the maximum number of concurrent users who can access the folder. On the Action menu, click Properties, displaying the Properties dialog box for the shared folder. The General tab shows you the user limit. Remember Win SP the maximus is 10. You can also use the Shared Folders snap-in to determine if the max numberof users that are permitted to access a folder has be reached.
Determine the number of connections to the share and the max connections allowed. If the max number of connections has already been made, the user cannot connect to the shared resource.
Jun 14, 2008 | Microsoft Windows XP Professional
INTERNET SETTIN
on your i-mate JAQ go to programs>internet sharing>connect.
prior to this pl make sure that your pda is connected to ur desktop via USB cable and it is synked with the desktop.
rgds,
May 10, 2008 | i-mate JAQ Pocket PC
I-mate jaq
my imate jaq doesnt connect to my pc. Is this a problem related to drivers. If yes, then I suppose the installation cd does contain a driver please advice.
Jan 18, 2008 | i-mate JAQ Pocket PC
Unable to use internet
there is a utility called i-mate configurator. Simply tap it , it will automatically detect the SIM card and if GPRS service is enabled on that SIM, it will configure it that too.
Dec 25, 2007 | i-mate JAQ Pocket PC
Installation in my laptop for internet access
i am unable to use my i-mate as a modem to acess internet by using my computor wimdowxp
Dec 24, 2007 | i-mate JAQ Pocket PC
i-mate JAQ Pocket PC Logo
122 people viewed this question
Top i-mate Computers & Internet Experts
iphone service
Oloyede Monsuru
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
