Question about Bernina Virtuosa 160
Service Manuals Hi There I am looking for a service repair manual for the Bernina Virtousa Sewing Machine 163
  • Merino Feb 26, 2008
    Thanks for feedback and assistance, will order the manual from suppliers
5 Suggested Answers
Mimito7
  • 128 Answers
SOURCE: user manual download bernina activa 140 sewing machine
Try this... www.2instructions.com
Posted on Apr 30, 2009
SOURCE: Bernina Virtuosa 153 QE Won't turn on
If you've got bad luck like I do, you probably blew out the circuit board! It took my Bernina dealer 4 months to get another from Sweden; thank goodness they gave me a loaner.
Unfortunately, it happened again right after I picked it up from the dealer, and they have to find another circuit board for it! It's not a problem with my electrical wiring because the loaner ran just fine.
It's very, very frustrating because I'm a small business and need my machine running!
Posted on Aug 17, 2009
SOURCE: service manual elna 722010 sewing machine
www.whitesewingcenter.com has the manual for an Elna 722010.
Posted on Mar 27, 2010
SOURCE: how do I change the
There is a small brown screwdriver/gadget that came in your accessory box included with the Bernina 1230. At one end, it is black plastic with a small point coming out of it. That end is used for tightening or loosening the screw that holds the needle in place. On the opposite end (brown on mine) it is hollow. This hollow end is pushed up and onto the lightbulb. (The bulb fits into the hollow.) Push up (firmly) and twist to the left to remove the light. To replace the bulb, insert the new one into the hollow spot on the holder and push it up and into the receptacle - twist to the right to lock it in place. There are actually two light bulbs, the one on the right is covered by a diffuser, but they both use the same procedure. It's easy to do and you are meant to be able to do it yourself. The pictures and instructions are on page 51 of the Bernina Guide. Hope this helps.
Posted on Nov 12, 2010
I need a Repair/service/parts manual for the Bernina deco 340 embroidery machine. I have the users manual
I've looked everywhere I can dig up for this, and while I've had success finding a number of manuals of one kind or another, no luck with this one, sorry.
Have you tried contacting Bernina ? You could maybe pretend to be a sewing machine repair person, if they're not happy seeing one go to an end user.
Oct 28, 2016 | Bernina Sewing Machines
Berninamatic 910 is frozen. Where can I find manuals so that I can service it?
Ken--
May be difficult to find for your machine because of its age.
Something may be close on this Bernina site (the 910 looks a lot like the 930 without the basting stitch, perhaps the needle up/down function, and fewer decorative stitches):
https://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/BERNINA-manuals/BERNINA-Sewing-Systems
BERNINA MATIC 910 ELECTRONIC SEWING MACHINE MANUAL CD
Most likely the machine has seized due to lack of fresh oil. The old oil has solidified and turned to glue and has stuck the moving parts together. Do not force it!
Remove the free-arm cover.
Open the top. (There is a metal peg on the top left with a screw slot in the center. Turn this screw 1/4 turn. Now lift the bobbin winder and you will see another METAL screw. Turn that 1/4 turn. Do NOT mess with the plastic screw unless you want to mess up the winder.) Now you can gently lift off the top. Pay particular attention how it fits as you will need to jimmy it a bit to get it back on without bending anything!!!
Now you can remove the cover on the left side over the needlebar.
Pick up a bottle of liquid Tri-Flow Synthetic Lube (hardware store or bike shop) with the small plastic tube dispenser. Gently rock the handwheel and apply a couple drops of Tri-Flow every place that metal rubs on metal. Do NOT oil the white nylon gears, the cams, or the belt!!! If you look closely, you will most likely see some small holes that are actually oil ports. There is a large one just on the inside of the case (left of the belt) that is part of the handwheel mechanism. This is probably where your problem exists. Do NOT over-oil or you'll be cleaning up oil for a long time and it could get into the electronics.
Work your way across the top of the machine. Be sure to move the stitch selector levers, the buttonhole knob, stitch width dial, etc and get oil into those metal mechanisms as well. There are 4 or 5 oil ports on the needlebar knuckles. Be sure to get those--one or two may be hidden so you'll need to rotate the handwheel and use the long tube to get to a couple. Oil the needlebar where it goes through the case, be sure to hit the presser foot lever mechanism.
Work your way down to the bobbin area. Be sure to get the oil port at the very back of the feed dogs next to the case (this is a very important one!). Get oil on all the metal moving parts and be sure to toggle the feed dog knob and get that mechanism too.
Now, take a handheld hairdryer and direct hot air into the internal mechanism of the machine. I've gotten the metal so warm it was difficult to touch. You may need to alternate between oil and heat, but if there is nothing mechanically wrong with your machine, this will get it running smoothly again. I've used this method on several seized mechanical Berninas and it has never failed unless a nylon gear is cracked or there is something else mechanically awry.
For sure, every time you start a project, apply a couple drops of oil where the hook and shuttle rub together (see the bottom photo below, the very bottom arrow on the left) or see page 45 of the Bernina 930 manual (Maintenance section).
Be sure to lube your machine often. Once you are familiar with the sound of a smooth-running machine, you will recognize by its sound when it needs some TLC. Other than that, plan to lightly oil every 40 hours of sewing. If in storage, every 6 months whether in use or not.
The photo below is actually a Bernina 830, but the mechanism is fairly similar to the 930/910.
Oct 09, 2016 | Sewing Machines
Where can I get power cord, foot pedal, and manual?
About 17,700 results (0.94 seconds) Search Results
    Bernette Sewing Machines - BERNINA Support: Machine ...
    www.bernina.com/...Manuals/bernette-manuals/Bernette-Sewing-Machin...
    Bernette Sewing Machines Within this section are the Bernette series of sewing machine manuals that are no longer ... bernette 50 / 60 / 70 / 75 Manual (7.4 MB).Missing: power
    [PDF]Manual - Bernina
    www.bernina.com/de/.../BERNINA.../bernette.../Manuals/deco340_EN_...
    Congratulations on your decision to buy the bernette Deco 340. By owning .... Insert the power supply plug into the wall outlet and turn the power switch on. 1.
    BERNINA Support: Machine and Accessories Finders, and ...
    Out of Print Manuals. Out of ... BERNINA FAQ - Find answers to frequently asked questions. ... Please note: this service can only address SOFTWARE questions.
    www.bernina.com/.../BERNINA.../BERNINA.../Manuals/0333017104_2...
    You've decided on BERNINA, a reliable choice that will delight you for years to come. For over 100 .... Power cable. ยท .... control the sewing speed by pressing the foot
Feb 03, 2016 | Bernina Bernette 75
Looking for Bernina 180E SERVICE/REPAIR manual for free download.
I'm sorry about this one but I usually have to pay for the service manuals. Many times I'm successful at getting User's Manuals for free but not service manuals.
Oct 24, 2014 | Bernina Artista 180
How can I get a Free Service Manual for Bernina 180
Chances are you won't be able to find any 180 service manuals anywhere especially a free one. This is a dealer only item and is not allowed to be sold or copied and sold. I did get lucky and I found one on eBay about 14 years ago when I first started servicing and selling used Berninas. The Bernina dealer I deal with will help me when I have a question or show me how to do a repair but he won't allow me to even look at a Bernina repair manual. Bernina is very strict about the use of their repair manuals so if you can find one, consider yourself lucky. And if you find one for free that would be simply amazing!!
Aug 10, 2014 | Bernina Artista 180
How to get a free Service Manual Bernina Artista 180 Sewing Machine?
You can find one here:
https://www.bernina.com/en-US/Meta/Search-for?searchtext=artista+180+manual
or via Bernina.com
Access service mode
Not sure of your model...
Here's a link to a bunch of free Bernina user manuals that might help ya, though.
Free Bernina Sewing Machine User Manuals ManualsOnline com
May 01, 2014 | Bernina Sewing Machines
Bernina service manual for 1008 - nothing on bernina website
I am struggling to find a manual online. Will keep looking. In the meantime, if it is urgent, buy one here: Sew4Less Manuals Service Repair
Mar 31, 2014 | Bernina 1008
I need a free download owner's manual for a Bernina sewing machine - model: Nina 1918 0r 3022
here is the link for the bernina website that has the only free bernina manual, if the manual is not on the site then you'll have to contact customer service and ask them about one, look toward the bottom of the page for manuals
http://www.bernina.com/en-US/Support-5
Sep 09, 2013 | Bernina Sewing Machines
Uneven buttonhole sides
Hi, I'm a Bernina tech and can tell you you need to have a technician recalibrate your buttonhole foot to the machine. There is a function in the service program to do this. Also the machine will need a speed calibration once the buttonhole foot is calibrated. This will definatly solve the problem.
May 23, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
42 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
