How do you refill an air con
Ive got the gas and the gauges but not certain how
    Master:
  • 518 Answers
With gauges you can simply watch the Temperature marks on the gauge... around 40 degrees F should be good. This is assuming the system was working and is still sealed. If any air or moisture got in, you'll need to have a pro come out and vacume it down.
When done you should have around a 25-30 degree drop across the A coil in the house.
Geno
Posted on Feb 25, 2008
How to regas a goldair air con unit
ok first the blue hose onto the suction line(the thicker of the two pipes)of the ac unit,the yellow onto the vacuum pump.the red hose not necessary.After vacuum is completed remove yellow hose from pump and put it on gas bottle now you ready to charge the unit
Dec 13, 2014 | Heating & Cooling
HOW DO I REFILL THE A/C IN MY '90 NISSAN MAXIMA
Locate the low pressure point, normally with the L sign on the cap, should be on the top pipe coming from underneath the windscreen to the front container, than get a proper filling gas ( must be the type used normally on your car), these containers come with pressure gauge so you should be fine, start the engine, put the fan on maximum, put air con on (make sure the compressor clicks in), and than attach the pipe to the low pressure point, observe the gauge as you do not want to overfill. Job done
Sep 27, 2010 | 1990 Nissan Maxima
Air is coming out but not cool
dear sir/madam
i think your air-con have low gas problem so please contact to your service technician for refill gas and further maintenance .
hope answer the question
thank you
please vote!
Sep 06, 2010 | Kenmore Heating & Cooling
Not cooling properly
dear sir /madam
please make sure air con annul service has been done if it,s already done .and same problem coming then it can be low gas problem .please contact to your maintenance personnel for refill gas.
i hope after that your air con will work well.
please vote !
thank you
Sep 05, 2010 | Sharp CV-P09FX Air Conditioner
I have a ford falcon ef sedan and whenever i use the air con the car starts to overheat (ive never let it get past the o in normal on the gauge) and i lose massive amounts of water. if i turn the air con...
What type radiator fan do you have? Fixed cconstant , viscous variable speed or electric?
Does it run cooler at highway speeds above 35 mph?
What is the pressure range on the radiator cap?
Is the coolant mixed at approx. 60/40?
Is the condensor and radiator clean and able to pass enough air?
Is the fan shroud on?
Genuine concerns, let me know, good luck
Jan 23, 2010 | 1983 Ford Fairmont
The HVAC registers in the car will not blow consistently, in a 2001 Ford Taurus. What are the possible problems? Sometimes the air will blow, sometimes it won't. Sometimes after the car is on for a...
Check pressure of air con fluid. Sounds like it needs refilling.
Most good car centres sell the gas in a can - with a pressure gauge.
Try this first as it's the cheapest option to start.
Aug 04, 2009 | 2001 Ford Taurus
Air condition won't cool.fan blows warm air.
sounds like the air-con gas is low switch on air-con a nd check to see if the compressor clutch is pulling in if not reove h/p dust cap on the aircon pipe press schroder valve to see if gas escapes if not will need re-gassing even if you get gas out without a pressure gauge it is hard to tell if the right anount of gas is in the system.
Jul 12, 2009 | 2005 Lexus Ls 430
Air con gas leaking & noises from under dash
Hi jrm the smoke under the wing is the fuel fired heater and is normal. the noise is the heater motors for the heater flaps, there is a jag fix but you have to replace all the motors just ignore it.  Try changeing the filter for the heater under the left side scuttle panel thats below the black plastic panel below the screen that will help the steaming up     D
Dec 30, 2008 | 2003 Jaguar S-Type
Air con not working, led comes on but no difference in temp. No engine noise difference when air con switched on. regards
Take your car to the shop for the refill of the A/C system. You have run out of the coolant gas ;)
Jul 14, 2008 | 2006 Volvo V50
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
