Question about SanDisk Sansa m240 MP3 Player
How do I recover files on my sansa m240??
I recently got a new PC and as soon I plugged my sansa m240 into it it seemed to erase all my mp3s. I unplugged the device and started it up and it said there were 0 files.
However a look at the drive space reveals that the files are still on there I just can't access them. Someone said if I downloaded a new version of wmp it would work but it still didn't work.
I fixed it. It turned out that the battery I was using was causing the problems (a zinc-carbon), an alkali battery is the only one suitable for the player. I managed to recover the files anyway (before I knew what the problem was) by using a program called PCI File Recovery.
Posted on Mar 28, 2008
    Problem Solver:
  • 9 Answers
Try using a different format on your songs like mp3
Posted on Mar 27, 2008
Used for years. Deleted mp3 files. Tried to reload new mp3 files by select all and drag and drop to audible folder. Message said it was full and would only load partial. Deleted partial load safely...
Sorry mate it has been corrupted and and may not work any more it seems the set up and read file that is like a operating system has been moved or deleted. The same things happens with usb drives.or has been disconnected without using the disconnect usb device icon.
Jan 31, 2011 | SanDisk Sansa m240 MP3 Player
No files but memory full, cannot acces files, pc cannot read file
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 04, 2008 | SanDisk Sansa m240 MP3 Player
Sansa m240 - deleted all songs - tried to install new ones- won't take-says full
-Tha Mp3 Doctor
Nov 09, 2008 | SanDisk Sansa m240 MP3 Player
My sandisk sansa m240 not working with my windows xp pc
Uninstall all Sansa software and reinstall it from CD.
If that fails:
-Tha Mp3 Doctor
Aug 19, 2008 | SanDisk Sansa m240 MP3 Player
How to remove virus?
i think you should remove the files(mp3s)from that and update the sansa´ firmware if you can.......(btw im not an expert,so if it´s a stupid answer sorry)
Jan 10, 2008 | SanDisk Sansa m240 MP3 Player
Uploading problems
I got my solution here:
http://www.mobileplanet.com/ft.aspx?k=72496
Nov 03, 2007 | SanDisk Sansa m240 MP3 Player
Sansa automatically erasing files?
next time you go to rhapsody right click the button that has you mp3s name an choose fomat device it will erase all files on your mp3 so you can put them back on
May 12, 2007 | SanDisk Sansa e260 MP3 Player
I can't delete files off of my mp3 player!
Hi, This is taken from another post, but might work for you as well: 1. Take the battery out of the Sansa player. 2. While the battery is out, plug the Sansa m200 player into another USB port, preferably a rear one or a self powered USB hub, on the computer. 4. If the screen reads ?USB Connected? when the Sansa player is plugged in with no battery, unplug the Sansa player. 5. Hold the "Menu Button" (Power Button) for 45 seconds. 6. Connect it to the computer again (still without the battery). 7. If the screen once again reads ?USB Connected,? disconnect the player and insert a new battery which has never been previously used. 8. Try powering on the player. If the above procedures (power cycle) didn't work, please repeat the process again but now hold the power button for 2 minutes and wait for at least 5 minutes before plugging in new set of batteries.
Jan 12, 2007 | SanDisk Sansa m240 MP3 Player
Freezing
Thank you for contacting SanDisk Technical Support. It is our goal to make sure you have all the resources you need to get the most from your product through your recent inquiry into our product line. We do apologize for any kind inconvenience this issue is causing you. For verification, does your computer have Windows XP as its operating system? This issue may be due to some sort of corruption on the Sansa m240 itself. We should try formatting the Sansa m240 as a possible solution. Caution: Formatting will erase all information on the Sansa mp3 player. Please be sure to have a back up of all the information before proceeding. If your Sansa m240 is currently frozen, please remove the battery (to unfreeze it), then put it back in, and connect it to your Windows XP computer. Since you cannot access your Sansa m240 to convert to MSC mode, please have the ?HOLD? button ?ON? so that you can have your Sansa m240 in MSC mode before plugging to your computer. To format the Sansa m240 on your PC, let us connect the Sansa m240 to your computer on an USB port preferably located near the power hub or to an external self powered USB hub, go to ?My Computer?, single right click on the ?Removable Disk? associated with your Sansa m240, and select ?Format?. Let us please make sure that, under FILE SYSTEM, we change FAT to FAT32, and then single left click ?Start?. This will erase all data off the Sansa m240 and correct errors on it, which should make the Sansa m240 usable again. We also recommend formatting the Sansa m240 another way. Please be advised again that formatting will erase all data. Please right click on my computer and select ?Manage?. When ?Computer Management? comes up, please click on ?Disk Management? on the left hand side. After clicking on ?Disk Management? you should now have a list of drives in the right side panel. On the right, look for the Sansa m240, it may show up as Disk 1, 2, 3? Removable Disk. Right click on the larger "Volume" rectangular icon to the right of the Removable disk and select ?Format? choosing FAT32. If you do not have the format option, please select "New Partition" and just keep clicking next through the Wizard that appears. After formatting the Sansa m240, please do try your Sansa m240. If applicable, please go the link below to download the firmware update for your Sansa m240. The link is: http://www.sandisk.com/Retail/Default.aspx?CatID=1326 or http://www.sandisk.com/Retail/Default.aspx?CatID=1376 If formatting and firmware update in your computer is not possible, please do try the process again on another Windows XP computer. NOTE: Please be aware that formatting is a normal and necessary method of drive maintenance and repair, and simply NOT formatting periodically can cause a drive to slip into failure due to the backup, and clutter of residual data.
Dec 27, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
73 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
