2006 Yamaha Roadliner Logo
Anonymous Posted on Feb 14, 2010
Oil drain plug removal
2006 roadliner. Can't get 17mm wrench on front plug to drain oil. Casing in the way. Is there a special wrench?
  • Anonymous Feb 15, 2010
    Can't get socket on it. Had to get a box end with thin walls.
Anonymous
Level 3:
  • Master 593 Answers
  • Posted on Feb 14, 2010
Anonymous
Master
Level 3:
Answers
593
Questions
0
Helped
175347
Points
1850
3/8 inch drive ratchet and 17mm socket.
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Jun 03, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
4081
Points
19
You will need a socket with very thin walls because there is very little clearance around the drain bolt.
  • rexall1 Jul 30, 2011
    the 17mm open end wrench in your tool kit works great for removing the drain bolts.just hope nobody tightened it the last time to super tight.
How to change oil and oil filter
17mm Socket or Wrench and then a special tool or spanner wrench that takes the cap off the Filter.... Rest is Easy.. Drain the Oil and make sure you put the Drain Plug back in before you start to fill the system.
1helpful
Where is the oil drain plug on a 2002 BMW 325i
It is located on the oil pan, please be advised the oil pan is also the casting that houses the front differential, and the engine oil drain is the hex nut furthest to the rear of of the pan . You will need a 17mm wrench to remove the hex nut . After you drain the oil, DO NOT over tighten the plug . The proper torque is 25 newton/meters or about 20 foot/pounds
2helpful
2answers
Where is the location of the oil pan drain plug for the mazda cx9. thanks
Jack up the front of your car safely and climb under.
Oil change
VERY SIMPLE,JUST TAKE OUT THE OIL DRAIN PLUG(17MM)WRENCH DRAIN THE OIL,REPLACE THE PLUG,THEN REMOVE OIL FILTER RIGHT ABOVE DRAIN PLUG AND REPLACE,FILL OIL ABOUT 3.75QRTS FOR A HONDA.
TIM.
I cannot get a crescent, 17mm socket, or 17mm open end wrench on the rear left side crankcase drainbolt to save my life. I can easily access and remove the oil pan drainbolt and the front crankcase bolt,...
The clearence between the bolt heads and crankcase is very tight u might have to take a old 17mm socket and grind it down a little to get it on the bolt head. I think one bolt is for the oil in the engine and the back one is for the dry sump, there is oil in both at any given time.
Roadliner oil drain plugs
Then it sounds as if a special wrench is needed to remove the oil drain plug, unless there is an alternate way to remove it.
So what you are saying is the frame or engine case is in the way of putting a wrench on the plug?
Here's link to a PDF downloadable owner's manual,
http://safemanuals.com/user-guide-instructions-owner-manual/YAMAHA/ROADLINER-2007-_E
Ok, I saw in the manual where the oil drain bolts are located, they are in a poor spot.
I suggest you call a dealer and politely ask what wrench they use to remove the drain bolts.
5helpful
2answers
Drain plugs
Under the crank case. Just take a small mirror & watch the bottom of the crankcase. You can locate the hexagon bolt in the reflection view.
I can't locate the oil drain plug on a 2007 Hyundai Elantra. Help Anyone??
Place container under oil drain plug under the engine oil pan, remove drain plug using 17mm socket or wrench.
Hope this tip helps.
r/
David
1helpful
Changing the filter on the 2006 Lexus IS250
oil filter wrench
Toyota part #09228-06501 or Oil Filter "F" Cap Wrench (from AutoZone)
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
