Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Problem regarding net working (share file and printer)
Dear sir
i cannot share file with another computer and cannot print a file while the printer is attached with another computer . while checking the firewall, the massage comes out i.e.windows cannot start the windows firewall/internet connetcion shareing(ICS ) service and (Error 1075:the dependency service doesnot exist or has been marked for deletion.
Please help
Thanking You
  • 4 Answers
Hi,, This can be resolved .. please reply back... so that we can chat or you can visit us at www.onclicktechsupport.com
Posted on Feb 25, 2008
I cant print shared printer but can test print
If you're trying to connect to another computer, make sure that computer is on, that you have enabled file and printer sharing on both computers, and that file and printer sharing can communicate through your firewall.
For more Help Read... Troubleshoot file and printer sharing and HP Printer Installation
Thanks
Jun 27, 2014 | HP LaserJet 1022 Printer
Foxpro 2.5 Application can't direct print in xp cause in my print Dot Matrix with Epson LQ-2180 using USB to Pararel Port...
share the printer then search for your own computer and you should be able to open it and see the shared printer like. \\server\printer
then use net use command...
net use lpt2: \\server\printer /Persistent:yes
then tell foxpro to print out lpt2 and it will act like dos
you can add net use command to autoexec.bat or windows startup if you will do this often
Nov 08, 2009 | Electronics - Others
Print queue will not clear after printing
dear sir
this is a typical usb inkjet printer problem
just follow the steps
open notepad
and copy paste
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
and save as delete.bat file on desktop
run this file and reboot the machine
and run this file again
now print queue will get cleared
thanks
Apr 10, 2009 | Dell 966 All-In-One InkJet Printer
My shared printer will only print a test page and nothing else!
Hi phall124
Have you made the new connected printer on 2 other PC's the default printer. Try selecting the printer in word by not just clicking on printer icon but using the following:
1.File
2.Print
3.Select printer from drop down box
4.Print
Regards
Go-Tech
Dec 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer
Please check the following link which has the troubleshooting steps to resolve the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bpu04830
Regards,
Sagarjd.
Nov 03, 2008 | HP Officejet 5610 All-In-One InkJet...
Use two computers with one printer
Printer Sharing (This is good for Windows 2000, XP and Vista)
Sharing will be very easy if your network is working.
You need to consider the computer where the printer connected as the "Host" and the other computer that wants to print to that printer as the "Client".
Before you do such sharing, you need to acquire each computer's IP address.
You can do it by accessing MSDOS Prompt and typing in ipconfig/all. Write down your IP addresses and the share name on a paper.
For your Host:
Install the driver, make sure that you can print on direct bi-directional connection (such as USB).
Go to Control Panel >Printers and Faxes* >Sharing >Share this printer >Type in your share name, good example is PRINTER (this is case sensitive).
For your Client:
Install the driver, make sure that you can print, same with the Host.
Go to Control Panel >Printers and Faxes* >Properties >Ports >Add Port >Add local port type in \\ (the IP Addressof the Host) \ (share name), click OK.
ex. \\192.168.1.3\PRINTER (watch your backslash, no spaces)
*Term used is "Printers" for Windows Vista and Windows 2000
Oct 23, 2008 | NetGear FS105 5x10/100 Mbps Networking...
Printer does not respond, and we restarted it and it still does the same thing
Whats the brand and make of the printer and are there any error lights being displayed ?
also try this solution it may solve your problem:
Click start > click run
in the Run window type cmd
hit enter
now a black DOS window will appear
now type
net stop spooler
wait 10 seconds
now type
net start spooler
it should look like this :
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\NCR>net spool stop
The syntax of this command is:
NET [ ACCOUNTS | COMPUTER | CONFIG | CONTINUE | FILE | GROUP | HELP |
HELPMSG | LOCALGROUP | NAME | PAUSE | PRINT | SEND | SESSION |
SHARE | START | STATISTICS | STOP | TIME | USE | USER | VIEW ]
C:\Documents and Settings\NCR>print spool stop
Can't find file spool
Can't find file stop
C:\Documents and Settings\NCR>net print spool stop
NET PRINT
\\computername\sharename
[\\computername] job# [/HOLD | /RELEASE | /DELETE]
C:\Documents and Settings\NCR>net stop spooler
The Print Spooler service was stopped successfully.
C:\Documents and Settings\NCR>net start spooler
The Print Spooler service is starting.
The Print Spooler service was started successfully.
Anymore information would be great
Thanks
Aug 18, 2008 | Office Equipment & Supplies
USB printing through DOS mode
Google for DOS PRINT USB, and you'll find some utilities that do this.
Or, you can include some commands in your batch file.
First, get the device name:
In a DOS window, type NET VIEW ComputerName (or use 127.0.0.1)
Once you know the printer share name, you use it in a batch file.
NET USE lpt1: \\ComputerName\ShareName /Persistent:Y
This captures the print queue to the shared printer.
You must also go into Printer Properties/Advanced/Print Processor and set it to TEXT
Your copy, print and other commands will work.
Jul 12, 2008 | Computers & Internet
Help please....printer name does NOT appear
You must have a network set up, and you must enable file and printer sharing on the desktop. The laptop and the desktop should be in the same workgroup. Some firewalls will cause this problem.
Start with the network setup wizard in Settings/Network.
Jan 25, 2008 | D-Link NETWORK CARD DFE550TXREF Network...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
