Question about Nokia 9500 Communicator
How do I remedy bad connection and reception?
My Nokia 9500 - all of a sudden - rings but I cannot hear the person on the other side. Also the connection is terrible, when I an able to receive calls. Can you help with a solution?
    Sergeant:
    Champion:
  • 283 Answers
Yes ... your problem needs to have your earpice fix, it needs cleaning or replacement of speaker,,..
Posted on Apr 18, 2008
I think the ringer is off on my NEC Dterm 80 phone. when a call comes in, I hear it ring at my bosses desk but not mine and my line is the main line. How do I turn the ringer back on. Thank you
Ringing is assigned in system programming, so if your phone doesn't ring you can't change that unless you have person on site who works on the system at that level. Some places use the night mode feature to make certain phones ring in day mode, and others to ring in night mode. Not very likely but sometimes the mode gets switched at places who don't realize they have another mode, suddenly only 2 phones ring instead of ...5. Feature,80,Feature, is the code to switch back and forth on a Pro II, an Elite, and an IPK system. This would be done at the reception phone. These phones also work on several other systems so don't know if this works for you. Or maybe you set Do Not Disturb, which would keep your ringer off.
Oct 04, 2013 | NEC Dterm DTP 32D-1 Corded Phone
When i make or get call I can hear them but they can't hear me. I get this yellow swiggly object on my screen.
There is some problem with your phone mic only.please use your headset to check it.Connect your headset and answer phone with your headset.If the person don other side hear you then the problem is with the mic only.Please take the mobile to NOKIA CARE centre and they will repair the mic.
The yellow colour swiggly object which comes next to the battery bar is nothing unusual.It shows that your call is been connected with the person on other side.This symbol will not appear when the other person's phone is ringing,When the person picks up the phone this yellow colour symbol will apear.]
Thank You
Thank You
Aug 12, 2010 | Nokia 6300 Cellular Phone
I want to shut off answering machine
Use the Reception Mode button to set appropriate answering mode - press it repeatedly until a small arrow on the display will point to the desired option:
"TAD" - is the one you are using now, when the answering machine picks up the calls.
"TEL" - is the setting when no automatic pickup occurs, you always have to pick up the call and either talk (if there's a person on the other side), or press START to receive a fax (when you hear the fax beeps on the other side).
"FAX" - is the setting when after four rings the fax will pick the call up automatically (no answering machine). If you pick up the call manually after 1-2-3 rings (before the automatic pickup) you can either talk or START fax reception.
It's good to check from time to time if the reception mode is as you want it, it's easy to change it by mistake.
Good luck and come back with a testimonial if helped :)
Jan 31, 2010 | Sharp UX 460 Plain Paper Thermal transfer...
Problem with Nokia 6300 - Can't hear anything
You need to changed,Your mouth piece, and you earpiece.
As for your ringer, it can be changed,but sometimes the problems always from the panel of the phone,and when it's from there, and ones is from there,it's damaged.
For your mouth piece and your earpiece it will workafter changing it.
Jan 20, 2010 | Nokia 6300 Cell Phone
I want to change full body of my nokia 9500
first on your task is surely to buy a genuine casing for your phone... changing it is another, it quite hard for a not-so-techie person to change it by himself because, 9500 series have a flex ribbon connecting the two boards(upper and lower) and it quite difficult to handle, and might get up torn.. i suggest you take it to an authorized nokia center for replacement of your housing
Dec 03, 2009 | Nokia 9500 Communicator
I have a Nokia 6085 cell phone. When you make a
you cell speakerhaving a problem change it ......
Jul 13, 2009 | Nokia Lands Phones
Nokia 5310 sound
Try going to
Menu>Setings>Call>Voice clarity>Active
Hope it works
Apr 11, 2009 | Nokia 5310 Cellular Phone
Nokia 6300 not loud enough
Hi.This problem may occur when the file is compressed or converted.Like if you compress a file from 20MB to 5MB, its quality gets degraded n ultimately sounds bad.
Other remedy may be to try using the same file in some other format.And just see the difference.
Please keep updated about this.
Dec 13, 2008 | Nokia 6300 Cellular Phone
I have a problem with 6610i set that I can't able to hear other person's voice -
This sounds like the speaker in your handset which transmits sound to your ear is either faulty or turned down. Check the volume on your handset is set to max.
If the speaker in the handset is faulty - to trouble shoot this try using a handsfree kit which plugs in to the bottom of the phone and if the ear piece works correclty on a call through the handsfree eairpiece then your phone may have a fault.
Please dont forget to rate..
Jul 16, 2008 | Nokia 6610i Cellular Phone
Nokia 3230
Just clean the surface of charge and hearphone and on the right side of hearphone there is one small hole see if there is some dust or something and clean it
Feb 28, 2008 | Nokia 3230
Nokia 9500 Communicator Logo
60 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
