Question about Hotpoint Aquarius WF210 Front Load Washer
Programme not moving on
Hi
My problem is that none of the programmes are moving on from wash to rinse to spin, Machine stops completely after wash then need to turn off machine and set to rinse and spin, it stops at the end of that without spinning and turn off again and set to spin. I guess it's something fairly serious ? I am in Dublin, Ireland
Mary
  • 3 more comments
  • MaryDublin Feb 25, 2008
    I presume "turn" means doing the wash,spin etc? Yes it washes etc., but stops completely at the end of each section and will only move on to the next step by restarting the machine and separately setting "rinse" etc. M
  • Anonymous Mar 31, 2008
    Similiar problem since last week, program stalling after wash, turning off & setting to rinse & spin, stalls after rinse, turning off & setting to spin. Also noticed a small amount of water has leaked onto floor.
  • Anonymous Aug 17, 2008
    wahing machine actually popped circuit breaker on consumer unit,after reset machine does not automatically go through wash rinse cycle . motor bushes checked found plenty of wear.belt is ok. Motor appears to operate normally and no burnt electric smells.I suspect control pcb or timer problem.
  • dan muggeridge May 11, 2010
    Does the machine turn during any of these cycles?
  • Anonymous Mar 15, 2014
    The manual states how to turn off but not how to turn it on. Certain programmes use rinse hold but it doesn't happen automatically so I guess I need to state whether I want it to rinse hold or not.
  • 108 Answers
This is not something like a belt or a motor then...It's probably the Logic in the control system.
Your best bet is have a hotpoint engineer diagnose it - and fit a new control module. To buy from hotpoint they range from 70 to 90 Sterling.
In england the call out is £90 and they actually don't charge for parts if the machine less than 5 years old.
Posted on Feb 25, 2008
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Hello, I have a beko WM5120W Washing Machine, and when I try to use the quick wash programme, it does the washing cycle ok, but when it starts the rinse programme, it pumps the water out ok, but when water...
hi
the water level switch or sensor does not activate to tell the programmer that there is plenty water so that it can start to rinse ( what you doing is simply overriding the system .
Dec 31, 2017 | Washing Machines
Machine wont stop washing on programme 9! went for days. Had the error lights flashing but that stopped.
If you select a rinse and spin programme and it completes the cycle, then I would say that the heater element is probably faulty, because the programme will not advance until the water has reached the correct temperature.
If it does not complete the rinse and spin cycle, then it is likely to be the control module that is the problem.
Feb 09, 2010 | Indesit W 123 Front Load Washer
Programme gets stuck on wash cycle
Most likely a defective door switch.
Mar 02, 2009 | Washing Machines
FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Dec 26, 2008 | Whirlpool AWM8143 Front Load Washer
Hotpoint Aquarius WMA34 not progressing through wash cycle
hi
iwould think it is the programer may have failed mechanically not moving on
cheers
grant
Oct 23, 2008 | Washing Machines
Indesit w11
does it have a manual programme knob?if it does ,probably the internal contacts do not mesh so it stops at next step (programme)but the water pump keeps on making the noise.
try turning the knob by hand when machine stops before entering next programme cycle.if machine starts ,programme knob is the problem.
Mar 21, 2008 | Washing Machines
Hotpoint Aquarius WF210 Front Load Washer Logo
140 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
