Question about Polycom (2200-07155-002) Professional Microphone
Polycom Microphone Feedback
When in a call the near/far end receives feedback
  • 682 Answers
Change your position and put the unit over sound absorbed material(mate covered with wool)
Posted on Feb 29, 2008
Onkyo skw 591 subwoofer...blue light is on and no sound? any thoughts?
Hello, To test the subwoofer when the blue light is on if you apply your thumb to the end of the subwoofer cable (the end that you would plug into the receiver) there should be feedback from the sub. If there is no feedback then the sub is not working correctly. Thanks, FJD
Apr 27, 2016 | Onkyo Audio Players & Recorders
Feedback 3-4 mtres from speakers
Feedback is caused by having the volume up too high or being too close to the speakers. Turn mic down a bit, feedback goes away.
Better speakers and mic will help.
Sep 11, 2014 | AKG WMS 40 Mini Vocal Set Handheld...
I have feedback when transmitting
Check your audio settings. Feedback is a condition caused when you are transmitting and your audio is coming out of a speaker (headphone) and is picked up by the microphone. Try turning your audio down; reducing your microphone gain; and perhaps using a wind sock (microphone cover) over your microphone to reduce the amount of feedback audio entering into the microphone (manual pg 13).
Aug 01, 2014 | Flightline Fligthline FL-760 VHF COMM...
Mic feedback with numark c3fx
Feedback occurs whenever a microphone is being amplified, and it picks up its own signal above a certain level. Unfortunately, there's no way to reduce this possibility using just the Numark C3FX - you can only turn the microphone level down. The only way to reduce feedback through a speaker system is to use a graphic equalizer. Here's a good resource for how to do that: http://rfmedia.hubpages.com/hub/Controlling-Microphone-Feedback-with-a-Graphic-Equalizer
Nov 07, 2013 | Numark C3FX 4-Channel Rack Mixer With...
Logitech speaker feedback
Feedback is a sharp, loud noise that can come through the earphones of a headset unexpectedly---it occurs when the headset is getting sound (feed) from someone else speaking or playing music into a microphone. This sound can create a dangerous situation for someone who is operating expensive equipment or flying a plane at the time since it can disable hearing temporarily.
If you experience feedback often, it could also lead to serious hearing problems.
Mic Too Close to the Speaker or Volume Too High
The main cause of a feedback sound in a headset is proximity to a speaker. If a person holding a microphone on the other end gets too close to a speaker, it creates a loop of re-amplified sound that results in the loud, screeching noise. When the volume on the other party's microphone is too high, it is more vulnerable to picking up unwanted noise and feedback from speakers and sound output devices in the room. So make sure that you ask the other party to turn down the microphone to a normal level and stay far from speakers. b> Two Microphones Gathering Same Sound b> When the other party places two microphones too close to each other, it could cause feedback. When positioned toward the sound source (such as a person speaking) the microphones will both pick up the same audio and compete with each other when creating the output of sound, causing a sharp noise in your headset. This problem, called acoustic phase interference, is resolved by simply ensuring that the other party uses one microphone at a time. Poor-Quality Headset or Microphone b> One common cause of feedback is simply a poor-quality headset or microphone. Most modern headsets and microphones have noise-canceling features that manage and kill feedback before it has a chance to occur. These noise-canceling headsets are essential for pilots and aviation crew members. If you hear sudden feedback that is strong enough to hurt your ears, the headset or microphone is simply not properly equipped to actively cancel that unwanted noise before it hits your ears. Buy a higher-quality noise-canceling headset to manage the feedback noise when you're going about your tasks. Hope this helps.
Dec 23, 2012 | Logitech Z623 Speaker System
Controller giving feedback?
If you are not using a microphone, then you are not the feedback source.
That being said, a blue-tooth headset still qualifies as a microphone, and is capable of generating feedback.
If using blue-tooth, then switch to a standard wired headset to determine if the feedback diminishes.
Regardless of headset type, be sure to have game chatter through the headset only setting as opposed to through the TV speakers, and keep the TV turned down. There will be an obvious lag between TV speaker and headset microphone which can create a feedback loop.
If other gamers can hear your TV when you are talking, then the TV output is too loud and will create feedback opportunities.
If none of the above applies, then the feedback is generated elsewhere.
Hope this helps!
Apr 22, 2012 | Microsoft Xbox 360 Wireless Controller
Low to midrange feedback
If the guitar can "hear" a speaker that is driven by it then it will feedback if gain is set high enough (doesn't take much). The guitar makes a wonderful microphone. Often you can actually see the strings vibrate while feedback is in progress. Keep the speakers facing away from these guitars to reduce the chance of feedback. Sometimes you can increase the threshold before feedback by using your EQ on the amp. The acoustic guitars are FAR more susceptible to this than the solid body electrics..
Mar 09, 2011 | Ovation Applause Series AE148 Super...
Feedback issues during live band performances
This is clearly a microphone problem. You need to review your mics and use a suitable type. Ensure the speakers are not aimed at the mics too.
May 12, 2009 | Audio Players & Recorders
Phone feedback
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Lands Phones
Microphone Feedback
Turn the volume down, even if it's off.
The laptop picks up on anything near it, not necessarily audible sound.
Dec 05, 2007 | IBM ThinkPad T22 2647 Notebook
Polycom (2200-07155-002) Professional Microphone Logo
443 people viewed this question
Top Polycom Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Polycom Audio Player and Recorder Expert? Answer questions, earn points and help others
