Question about Canon Rebel XT / EOS 350D Digital Camera
Camera won't talk to lens
The camera body seems to power up fine, but there is no display on the lens (through the viewfinder) and it wont take any pictures. It seems that the lens is not receiving power and/or not communicating with the camera body. I have tried two different lenses, both have the same problems.
This problem is with my Canon 350D. Thanks!
    Genius:
  • 1,027 Answers
Is the lens switch in manual or auto mode?
Posted on Jul 10, 2008
I am new user for DSLR, using old 50 mm 1.8 manual focus on D80, unable to see any inmage on playback (shows information). Will this lens work with D80, using settings as manual mode, f22 . Please guide...
Turn the aperture ring to its smallest setting (largest f/number). You control the aperture from the camera body, as on a lens without an aperture ring. Turn the mode dial to M (manual). The camera's exposure meter will not work with this lens. You can use another lens to get an approximate exposure, or take pictures and review them and/or use the histogram to fine-tune the exposure. The camera won't autofocus, of course, but the in-focus indicator in the viewfinder will still light up to indicate proper focus.
Jun 17, 2011 | Nikon D80 Digital Camera with 18-135mm...
When i look through the viewfinder its darker than usual, my lens wont seem to come off its stuck even while holding down the release button and trying to rotate it by force. When taking pictures on auto...
Hi tin_080 , the aperture actuating lever was bent or loose and is ahead of the control mechanism of the diaphragm opening in the camera body.
Check this: point the lens towards you notice that the diaphragm is closed.
To avoid more costly damage you take it to a workshop for servicing.
Best regards
Mar 26, 2011 | Nikon D90 Digital Camera with 18-105mm...
Digital viewfinder not working
Sounds like a loose or poor connection of the screen's flex cables, a very common problem for your model camera. The A630's vari-angle screen is a great option for a camera, but with this moveable screen, the screens data and power cables can and do wiggle loose. It is actually relatively easy to fix by just reseating these cables, but will require opening the back face of the screen of your camera. Please see this other person who had a similar problem.
May 03, 2010 | Canon PowerShot A630 Digital Camera
Canon, wont focus, dark viewfinder
try cleaning the contacts on the bottom of the lens, where it mounts to the camera body. This is a simple step to take and one that I try to remember to do frequently when I am switching back and forth between lenses frequently. get a magnifing glass and look closely at the contacts on both the lens and body. I have 5 canon bodies and the 75-300 IS lens is one of my favorites. It is ALWAYS mounted on either an XTI or XSI and within arms reach at all times. I have a hook and hang it from the headrest of the passenger seat when driving so that it is always ready at a moments notice. I have never had a problem with that lens.
Jan 24, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Viewfinder and LED display both black.
Try pressing the power ON and when the lens has retracted, remove the batteries. Wait a few minutes. Press the power ON again. Now replace the batteries and try the camera again.
Aug 20, 2009 | Nikon COOLPIX P60 Digital Camera
My Canon EOS 1000D wont take photos, viewfinder flashes busy
Maybe you drop your battery and they have electronic components inside that could be spoiled, if is that the case, try to change the battery, it appeares to me that the ammount of current the battery is sending to the component is very low even thoe it seems to be fully charged that's why the camera is unable to display anything and the "busy" warning is blinking all the time, I hope you find this usefull.
Aug 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Cleaned inside of viewfinder, now AF focus lights gone
Then you learn, when everything works fine, dont mess with it! Have a look at the gold pins that rely the body to the lens. Also check that your lens manual switch focus is engaged... Try a friend lens to see if its your cam or the lens...
Jul 29, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Really Dark Viewfinder
That would explain the darkness if the lens is stopped down. It would seem the aperture control is faulty on the camera body. Normally, the aperture remains open until you take the picture. It is only closed down while the shutter is open.
Feb 11, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Fuji Finepix S1 Pro fE E blinking when turned on?
Might Help:
Notes on G-type Nikkor and other CPU Nikkor lens
The G-type Nikkor lens has no aperture ring; aperture should be selected from camera body. Unlike other CPU Nikkor lenses, aperture does not need to be set to minimum (largest f-number). CPU Nikkor lenses other than G-type Nikkor lens have an aperture ring. Set the lens aperture to its minimum and lock. When the lens is not set to its minimum aperture setting and the power switch is turned on, "fEE" blinks in the control panel and viewfinder and the shutter cannot be released.
Nov 09, 2007 | Fuji FinePix S1 Pro Digital Camera
No display in record mode on Samsung VP-D31
Sounds like you may have a problem in the auto iris curcuit or the auto settings was switched to manual and the lens is closed. Check first to see that the lens is setup in auto mode. If it is then the auto iris as i said before is bad or stuck closed unless the small caps in that curcuit went bad as they always do after a few years. Good Luck
Apr 14, 2006 | Samsung VP-D31 Mini DV Digital Camcorder
Canon Rebel XT / EOS 350D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
