Question about Casio G-Shock GW300CA-1V Wrist Watch
Casio G-Shock GW-300 2608
The backlight light doesn't work it charges ok, and indicates high but no backlight.
  • 3 more comments
  • Anonymous May 02, 2008
    I bought watch in Guam, but ever since returning to the states in 2007, my watch doesn't receive the correct time. I depress the rec button but it only displays the wrong time. what should i do.
  • Anonymous Jul 04, 2008
    Battery depleted, was too low to charge. Can't find battery specifed by Casio Manual Module No.2608: Casio battery specified is CTL-1616.
    I did not want to replace with on off brand battery.
  • DaveNagy Jul 11, 2008
    I too have the same issue with the backlight not working at all - whether pressing the button or in the dark by flicking/turning my wrist. The charge/battery indicator is on 'high'. I have replaced the battery once before.
    Thanks!
  • ptransitpoky Feb 01, 2009
    The light does not work anymore. Sometimes it will flash but not enough to tell time in low light
  • Anonymous Feb 15, 2009
    That is just not the case, for me. Have replaced battery and the light does not function. Jeweler did it. He says get a new watch.
Change the battery. This happened with mine along with the battery needing charging more frequently. In my opinion, Casio's assertions that you won't need to change the battery is pretty much of a joke. My jewler concurred.
After changing the battery I can now press the light switch button and the watch works normally.
Tony
Posted on Mar 09, 2008
    New Friend:
I've had mine for 13 years and this is the only time anything hasn't worked.......the battery won't hold a charge. No complaints
Posted on Jan 04, 2013
My casio just went blank one day!!
Posted on Mar 08, 2008
Removing metal wrist strap casio gw-3000bd
With most watches, use an Exacto knife to compress the pin to remove it. Replacing the pin is more difficult.
Nov 13, 2014 | Casio G-Shock Tough Solar GW-3000BD-1AJF...
I've got a Casio G shock GW 2000 (solar multi band) for 4 months It's still working showing the correct time but there is no way I can make the second hand to move at all. It's stuck at 8 despite the fact...
I suggest you go to "Casio.com", click on "support" and then "contact us" and give them a call.
They should be able to sor tout your problem for you but if your watch is faulty, then I'm sure they will replace it for you.
Feb 14, 2011 | Casio Watches
My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
Jan 11, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
Casio g-shock gw-330a watch. I saw the utube
http://world.casio.com/wat/download/en/manual/
There are so many aplications use of the manual will be manditory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
Mar 20, 2010 | Casio GW330A G Shock Solar Atomic Watch
I have a Casio Shock Risist watch (GW-500A) that says "charge" on the display, that is all it shows. Does it need a new battery or what?
this watch requires no battery. It uses solar cells. my watch did this as well. to make the watch functional again my advice is to not wear the watch for one day and place it near a window that gets a lot of sun.
Nov 24, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Casio G-Shock GW-300 replacement bands
I have a Casio g-shock gw-330a and now find myself again replacing the band. So far, $60 on bands. They last me two or three years. To install the band, take the band and watch to a Jeweler. My local Sears does it for me. $5 for installation; $5 for purchase shipping; $20 for band. $30 every couple of years.
This cost disturbs me.
Jun 09, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Need to replace casio atomic solar watch 2608 gw-300
Check out this YouTube video which walks you through the battery change process:
http://www.youtube.com/watch?v=ogCz2vjUKVg
May 14, 2009 | Casio Watches
I just recently purchased a brand new Casio G-Shock GW-002KA 2913
if there is a black screen and shows chg thats mean your battery level is to low ////// so you must charge as soon a possible,,,,,,
Jan 21, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
7,020 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
