Question about Olympus EVOLT E-500 Digital Camera
How do I reset?
My dear sweet hubby took the E-500 on a flight and now the flash doesn't work in ANY mode. I've looked all through the manual but cannot find a master reset. I'm fairly certain he just hit the wrong button and a reset would fix it. When I go to the first screen that says reset - it is blacked out and I cannot access it. Any ideas on how to get this flash working? Even when I set it to manual full-on flash, I still get nada.
  • joecreatin Apr 12, 2008
    the pop-pup Flash of my e-500 is not working I hear the noise that sounds when flashing to detect the subject and I can see some sparkling electric in the middle right of the torch, and sometimes trying the torch make a flash but is week.
    I already clean up, the battery is already charged, and I'm buying a FL-36r, too make the shoots. but I need to know if this is fixable.
    Problem Solver:
  • 3 Answers
It sounds like the strobe is not making good contact with the connection on the camera. Check to see if the pins on the camera aren't covered with crap and the pins on the bottom of the flash aren't bent or broken.
Good Luck.
mwh2385
Posted on Mar 08, 2008
How do i get the flashed turned on
First, check to make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Slide the switch away from the flower toward the mountain to take it out of macro mode. The flash won't fire in macro mode.
Then, if the flash still doesn't fire, take a look at the flash mode. Press the up-arrow button to bring up the flash menu. If it's currently set in the lightning-bolt-in-a-circle-with-a-slash-through-it symbol, you've got the flash turned off. Set it to the lightning-bolt-and-"A" for automatic flash or the lightning-bolt for forced flash.
If the flash still doesn't fire, then it's broken.
Sep 10, 2011 | Vivitar ViviCam 5024 Digital Camera
I dropped my camera in a shallow bowl of water, and took the battery and card out straight away and left it to dry out overnight. I've tried it again today, and its taking photos again, and the lcd...
1. The best thing to do is to factory reset the camera to be sure everything
is in the default setting. Look in the manual or menu to RESET the camera.
2. If this does not work, you can try is to remove the battery and wait a day,
then put the battery into the camera again and recheck.
3. If that does not help either, your camera might need repair/maintenance.
Sep 03, 2011 | Olympus EVOLT E-410 Digital Camera
Running in TTL mode with Nikon D200, flash EF-500 DG ST NAd, doesn't work. In manual mode everything runs well.
this flash is not compatible with the d200. i had one and sent it back to sigma, they upgraded the software in the flash for free. now it works in all modes, it needs to be iTTL to work on the nikon d200 the NAd version is not iTTL.
Jan 01, 2011 | Sigma EF-500 DG ST for Nikon Flash
I have a htc x 7500 advantage i ve installed a new windows on it after doing that my phone doesn t recive any GSM signal what can i do to fix it? where can i get the software for the phone application?...
You can connect to the Internet through Wi-Fi, GPRS, Dial-up, or Work connections(such as VPN and proxy connections). If you are encountering problems :
.Open the Comm Manager and make sure Flight Mode (or Airplane Mode) is turned off.
.Make sure the connection method settings are correct before accessing the Internet.
.Make sure the connections have been activated (e.g. Bluetooth, Wi-Fi etc.).
Jan 26, 2009 | HTC Advantage X7500 Smartphone
Flash-Off Problem
Do you have the camera in the auto mode?
Did you check to make sure that the auto focus is not in the manual mode when the flash is turned off?
If the above does not comply, call the tech support for the camera.
There is also a possibity that there is a defect, or that the flash is part of the auto focus function.
Jerry G.
Sep 15, 2008 | Olympus ? Stylus 500 Digital Camera
Phone only works in FLIGHT MODE
i have purchased a sigmatel s90 dual sim phone but by mistake i entered flight mode. Please send me details in english to get back to the normal mode and if possible could you send me the details in english
Aug 18, 2008 | Sony Ericsson K800i Cellular Phone
Olympus e500 internal flash not working
try resetting the camera back to factory defaults by putting camera in P mode, menu, custom reset
Jun 08, 2008 | Olympus EVOLT E-500 Digital Camera
Audiovox smartphone stuck in Flight Mode
You can Hard Reset the phone by either of two methods. Start/Settings/Clear Memory, or power on while holding both left and right softkeys down.
This resets and reloads the phone software system its ROM and you will lose any and all personal data and apps you put on it since receiving it. Back up all you can before hard resetting.
Apr 12, 2008 | Audiovox SMT5600 Smartphone
Amana Gas- Easy touch 500 diplaying code: 5ab
To cancel Sabbath mode:
1. Press the clock pad for 5 seconds
OR
2. After 72 hours, the Sabbath mode will end.
* SAb will flash for 5 seconds
* The time of day will return to the display
Hope this helps, I took it straightt from my owners manaul :)
Mar 13, 2008 | Kitchen Ranges
Slow taking pic, flash flashes multiple times while lenses acts like it is trying to focus
The evolt cameras use the flash bursts as a "autofocus help". Try to find points with high contrast or edges to point one of the three autofocus points at (you see these points while looking through the viewfinder and they flash red as soon as the camera is focused).
So, flash bursts basically mean "too low light" some other situation which is hard for the camera to focus. In such situations, try to switch to MF mode (manual focus). Or you could buy an external flash (e.g. Olympus FL-36) which has a red light for autofocus assistance instead of flash bursts.
Dec 05, 2007 | Olympus EVOLT E-500 Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
148 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
