Question about Mag Innovision InnoVision LT 765S 17" Flat Panel LCD Monitor
Model 780 monitor
Unable to view the bottom bar on the screen. It is visible on my portable screen. how can I adjust the monitor to accommodate the important info at the bottom?
No start bar at startup
right click in the desktop you will have an array of options this will vary depending on your operating system view refresh personalize and screen resolution
also your monitor might have some adjustment tabs where you will be able to adjust the settings
hope this helps
Jul 08, 2012 | Dell Computers & Internet
I have a wide screen Acer monitor, yet am unable to view my whole web site without scrolling down. I have adjusted the resolution to allow the font to fit on the page, and can see it perfectly with IE,...
Sounds like either your display resolution needs to be set higher or when you bring up firefox after the page loads press and hold the ALT key and Click View, ToolBars and select Menu Bar. This will keep it at the top everytime you open firefox. Now under View you can zoom in and zoom out. You can also select Full Screen. *** Before doing anything did you click the middle box at the top right hand corner of the screen between the - and red x? This toggles between full screen also.
Feb 25, 2018 | Acer X243W 24" TFT wide format screen 24...
Power supply to Mag 780 Model
No, it has a normal, seperate power cord. But the socket in the monitor is very small, it's a small round one. When facing the monitor from the back, it's located directly to the right of the monitor-stand, at the bottom-side of the screen. Just put the monitor on it's side to see it clearly.
It's all explained with pictures in your monitor's manual which you can download from the official website here: http://www.maginnovision.com/Support/Downloads.aspx?sn=464
Aug 23, 2009 | Mag Innovision LT776s 17" LCD Monitor
Running as second screen, drivers WILL NOT download from cd
on your display settings ehere you genreally adjust your resoultion. if you have connected 2 monitors ,you can now sww 1,2 monitors there on the sampl screen. click on the other monitor and change the resolution.
Aug 06, 2009 | LG W1934S-BN 19" Monitor
The screen is stretched there is nothing distorted
What kind of monitor? They can all be adjusted for width and height by using the buttons along the bottom of the screen. Often it can be confusing and a bit of a pain but look under the monitor menu for 2 sets of icons that look like 2 boxes on top of each other both horizontal and vertical. That is how you adjust it.
May 29, 2009 | Acer AL2216WBD LCD Monitor
New fx 5500 installed, now viewing screen too big for monitor.
Hi there. You just need to adjust your resolution settings in the Nvidia Control Panel. Just right-click anywhere on the desktop and it should be in the list.
Hope that helps.
If you need anymore help, just reply to the post.
Tim
Apr 17, 2009 | XFX GeForce FX 5500 Graphic Card
I have a 2002 MAG INNOVISION FLAT SCREEN MODEL 780. I use this monitor as a dual monitor with my lap top. However today I still can view everything but with a pink hue. I have gone to the color controls on...
This could be a problem with the monitor's data cable. Try to check it & find if there is any bent pins on the connector.
If this is not the case, there could be a loose connection on the monitor's PCB, or a failing component. This needs to be checked by a qualified technician.
Apr 12, 2009 | Mag Innovision Computers & Internet
Monitor problem
try the degus. it should work
Jul 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
Acer Aspire 5000 Monitor screen; bottom two thirds are unusable
that means your lcd is going south..happens over time..this thing under warranty by chance?
Jun 15, 2008 | Acer Aspire 5100 Notebook
Unable to have 1280x768 full screen with DVI cable
Use the menu button on the monitor itself to adjust for the screen size in DVI mode.
On your SVGA adapter, go to your display properties (right click on desktop) click ADVANCED and change the refresh rate to fix the first problem mentioned.
Oct 15, 2007 | ViewSonic VG2030wm LCD Monitor
Mag Innovision InnoVision LT 765S 17" Flat Panel LCD Monitor Logo
120 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
