Question about Car Audio & Video
8 Inch Pioneer limpids
I'm trying to biuld a back board for my limpids, but i no longer have the templates as the box was thrown away. how do i work out what domensions to cut?
    President:
  • 778 Answers
Find a new set in the box, and right down the dimensions (that you obtain from the box with a tape measurer that you bring in, in your pocket). Having a small rough sketch already on a note pad or paper that you carry in with you to add the dimensions to would also help. You may also be able to get the information needed to make the templates or even the templates themselves at the Manufacturers support site.
Good Luck.
Posted on Feb 25, 2008
Will pioneer plasma 50 inch pdp-505pe work with any other media box
just check the media box does have a connector like your TV.
The Pioneer 505 does not have a HDMI connector so it will be difficult to connect the modern boxes.
Find a box with a SCART connector.
Mar 13, 2015 | Pioneer Televison & Video
Pioneer 521 receiver shut off during a movie and then smelled like something burnt, now the receiver will turn on but turns off right away
Burnt smell means a mother board/circuit failure somewhere in the box. There is no owner fix for this. If you open it up you will probably see the charred solder. Back to the dealer
Mar 08, 2014 | Pioneer Audio Players & Recorders
Pioneer elite tv turns off from a pop sound and manual says-will
It is most likely the power supply. Do not try to fix this yourself. There are LETHAL voltages inside such a TV, which can persist for WEEKS after it has been turned off.
Jan 09, 2010 | Pioneer PRO-710HD 64" Rear Projection...
Going back to school after a 30 year break. calculators have changed a bit. is there a tutorial for the casio fx-115es?
If you had used calculators before you will be able to regain your former form in a cinch. The major change, from your point of view is the replacement of the EE, or EXP key by one labeled clearly time 10 to the power X.
If you use the MthIO mode your mathematics are even more limpid: You have a template to enter each parameter in its right place, exactly as you would write an expression by hand. With this calculator you can even calculate logarithms in any base. When you press the log key with a small solide rectangle below the level line , the template that displays will be clear to you: You put the base in the small rectangle and the argument in the larger rectangle. If you see that a left parenthesis is displayed you insert a closing right parenthesis where you would enter it if you were doing it by hand.
Trust yourself you will catch pretty soon. Make frequent use of the manual and the appendix.
If I find any tutorials I will insert the links here. In the meantime, I am including the link for the manual and its appendix.
Jan 07, 2010 | Casio FX-115ES Scientific Calculator
ViewSonic RC00136P Not Working
Open the battery compartment, remove the batteries, and examine
the small springs at the POSITIVE end of each battery holder.
Sometimes these springs get compressed and no longer make
contact with the battery. Use a small knife point or small screw
driver to stretch the spring away from the case until it extends
about 1/8". Replace the batteries in their proper orientation and
try the remote. This worked for mine.
Jul 13, 2009 | Televison & Video
I GOT A BOX THAT POPPED UP ASKING FOR THE USER CODE THIS IS AN OLD PRINTER I HAD IN THE BASEMENT AND HAVE SINCE THROWN AWAY THE BOX AND PAPERS AND NO LONGER HAVE THE CODE
I want to solution for the printer Samsung ML-2571N.Red led continuously blinking,but selftest is coming,I am sending a printout from my computer,it is errorpage coming.please tell me,what is the problem.
Jun 30, 2009 | Lexmark X75 All-In-One InkJet Printer
Tv shuts off
remove all the external connections connected to the tv.then un plug the tv wire from the power outlet.then after some time just plug only the tv wire back in the power outlet.do not connect the other devices and check if the tv is working as normal or not.if it does not works then
its the problem in the power supply board of your tv.
check for the fuse on the power supply board.
for any blown capacitors or ics.on the powersupply board.
also check for any loose soldering joints on the power supply board.
calling a tech is much advisable.if do not have proper technical knowledge.
it will not be too costly to get it repaired.
it is worth getting it repaired.as this is a common fault faced by many customers.
thanks.
May 28, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Unknown model of panasonic tv problem with picture
Depending on age, it sounds as if picture tube has an intermintent short in the red gun. tap on the center of the screen to see if it goes away, if it does,I would strongly say that the tube is gone; but you could try openning it and check if the crt board is mounted on the tube's neck properly. do this at your own risk since you might get a shock if not familiar on how to handle tv's.
Nov 20, 2007 | Televison & Video
Car Audio & Video Logo
211 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
