Level But not quality
I have a traxis 1500 box i only get level but no quality... when i put on my pansat box it is working....
  • Bajanprince Feb 25, 2008
    thanks... if it'e the defective LM317 IC or a TIP42C how can i get them fix
  • 2,326 Answers
If you only get level signal on the traxis 1500, it means that you may have a defective LM317 IC or a TIP42C. This part is mounted on a heatsink.
Try checking the LNB frecuency as well and make sure you have the same settings as your Pansat.
Good Luck.
Posted on Feb 25, 2008
Got a dbs traxis from sister and need to reset password
  • To reset the password you need to first restore this unit to factory defaults. Then you can use the default code "0000" or have the old code and change it to a different code entering the old code first.
  • To restore to factory defaults follow these steps -
  1. Use the ^ v arrows to select "erase all channels" or "factory default."
  2. Now press the OK button.
  3. There will be a warning display then just press "OK" again.
  4. The receiver is now restored to factory defaults.
Regards, Tony
Jun 14, 2011 | Traxis DBS-1500
Power steering does not work turning right. what
Hi Ben,
Air in the line. Be sure the steering fluid level is up to the fill line.
Turn the wheel to the stops both ways a couple times.
Check the level again.
Repeat until the level remains static,
Best regards
Apr 30, 2010 | 2003 GMC Sierra 1500
How much oil goes in a 1998 VL 1500? Never done
Drain your oil. Get several quarts of oil that Suzuki recommends for your VL 1500. Fill it until your dip stick indicates the proper level.
Dont get cheap on this ... motorcycles take q beating and need high quality lubricants.
Apr 11, 2010 | 2002 Suzuki VL 1500 Intruder LC
I have a Dazzle DVD Recorder but don't know what to put in the "recording time" field. I want to record a full 120 minute VHS tape but won't let me enter 120.
It is becuase the dazzle device is not selected as your video source. Please try to go back to step number 1 then click the box says pinnacle file capture then select the dazzle then try it again. :-)
Jan 25, 2009 | Pinnacle Dazzle DVD Recorder
Traxis DBS-1500 Remote code
What i need is the program to load the channels
Sep 03, 2008 | Traxis DBS-1500
Car Audio
Find out if the stock stereo has RCA line level outputs.
If it doesnt, you might want to use a speaker level to line level adaptor box. This will drop the amplified signal that runs your speakers to a low level you can feed into the amp.
If it does have the RCA lines, those would be preferred.
Choose an amp that puts out at least 200 watts RMS. Many amps are overrated. Look for the RMS rating in the fine print.
Dis-reguard the "Peak Power" ratings. They dont mean a whole lot.
The box the subs are in is one of the most important things in the system, because if the box doesnt preform right, you simply wont get the bass. You might get a box at a second hand store or garage sale that would out preform some of the boxes you might find at a WalMart. (The design of the box is everything)
Then make sure you get some quality subs in the box.
Also remember that sometimes a SMALL, quality sub could out preform a LARGER sub of lower quality. Theres no need to use up all of the cargo space in your vehicle for the sub and not have room for anything else.
God luck!
May 21, 2008 | Car Audio & Video
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
