Question about Sharp AL-1641CS Laser Digital Copier
Sharp AR 250 with error code H5-01
I have this problem on my sharp AR250 copier each time I switch on an error H5-01 comes and I can not print an thing I have charged the fuse with a new one
john
  • 2 more comments
  • mikeseebo Aug 25, 2008
    H4-01 error code..Is there a way to reset?
    thanks
  • Anonymous Oct 30, 2008
    i'm diff with error code h5-01 sharp ar-f230 . can you help me releas code, thanks
  • Anonymous Dec 23, 2008
    error code 205
  • MNABAVI Apr 23, 2009
    ON THE SCREEN IT SAYS CODE:H5-01
    Sniper:
  • 71 Answers
SHARP AR250 H5-01 Papersensordefective in the fusing unit
Normally you can clean the build up of toner off the sensor, and it'll sort itself out. It also could happen by having 5 paperjams in a row.
You might need to run a service mode to reset the machine:
P * C * 14 (start) then 1 for Yes and follow on screen directions, code should clear out.
Posted on Feb 25, 2008
    Problem Solver:
MY SHARP COPIER AR-M206 SHOWS SERVICE ERROR CODE H5-01 WHAT DO I DO?
Posted on Mar 19, 2011
Any time i switch on my sharp AR-250 code like C1-00,H5-01 appears on the screen.Which makes it impossible to print on the machine
the c1 code is a cassette missfeed. h5 is lower thermofuse. you need a tech to come out and repair your fuser
Dec 30, 2009 | Sharp AL-1641CS Laser Digital Copier
What code can i use to claer code:H4-01?it is a sharp AR-250 digital photocopier.
Press P, Interrupt, C, Interrupt keys in that order. It will ask for sim code, press 14 press print then Execute and it will clear.
Nov 12, 2009 | Sharp AR-C160 Color Copier
Sharp ar c260m error code f9.00 print function out of service
F9-00 is "AR-NB3 communication trouble"
that is the NETWORK PRINTING / SCANNING
EXPANSION KIT. that is the box that hands on the back of the machine.
Aug 12, 2009 | Sharp AR-207 Copier
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5320 giving me L 4 error some time
Usually the error is caused by a main drive over load. The machine needs to be looked to determine if its the motor, power supply, or a board.
Sep 19, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-M350N/H5-01
Hi, to reset H5 follow this sequence: P, *, C, *, display should read 'enter simulation', enter 14, print, execute, yes. Should re-boot if not switch off then on.
Cheers
Andy
Jan 24, 2008 | Sharp AR-5320 Black and White Copier
Sharp AL-1641CS Laser Digital Copier Logo
4,681 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
