Question about Technics SL-1200MK2 Turntable
Motor When im playing a record it wont keep a constant speed it slows down and speeds up slightly.
Thanks, now I can throw it away.
Posted on Mar 20, 2008
  • 515 Answers
This is a drive issue. You will need to have it professionally serviced, as there are many issues which may affect the drive of this unit. FYI, there is no 'motor' in a direct drive turntable. It is driven by various circuits on a circuit board, and if any one of them goes bad, your drive will be affected. The issue could also be a faulty pitch control as well.
- DJ PRO LAB
Posted on Mar 01, 2008
  • TERMiNAL OPTiC
    TERMiNAL OPTiC Mar 21, 2008
    Don't throw it away. We buy damaged 1200s! Can always use for parts. We are masters with the 1200s. We buy in any condition. Contact us HERE.
    Thanks.
    - DJ PRO AUDIO
    www.DJPROLAB.com
How do I fix a turntable used for playing records from being slightly slow
Try replacing the drive belt. Look under the platter for a 'rubber band' that would connect the platter to a drive motor. I bet it's loose. My other idea is crazy, however, they do sell an item called a "variac" which has a knob to control the voltage to the player. It's big and bulky and not worth the trouble. I'm a musician so I have to have a player up to speed or slightly detune my guitar. Good luck..
Jan 13, 2015 | Audio Players & Recorders
Motor surge at constant driving speed
Acceleration is defined as a change in speed, either a negative acceleration (slowing down) or a positive acceleration (speeding up). If you have constant speed, you are not accelerating.---------------------------------------------------------------------------------------
Multi-Di@g Access
Jan 14, 2013 | 2005 Jeep Grand Cherokee
Yorx turntable speed issue, And turntable is warped.
You may be experiencing Acoustic Feedback, although it doesn't really make any sense the way you describe it. Make sure the tonearm is balanced and the proper weight is dialed in on same. Does it make any difference if the volume or bass are turned down, which my point to the Acoustic Feedback.
Jul 04, 2012 | Audio Players & Recorders
My records that are 33 and 1/3 don't play at that speed on my turntable. they sound more like a 30 speed, what do I do
Hello Rosie,
Some turntables have a pitch adjustment feature which allows you to speed up or slow down your records. The adjustment controller is usually a slider or a wheel somewhere on the turntable and is usually labelled "Pitch" "Adjust / Adj" or "Pitch Adj".
Please check for this feature on your turntable then get back to me if you are unable to find it. Please include the brand and model number of your turntable.
Hope this helps.
Regards,
BElectric
Aug 17, 2011 | Audio Players & Recorders
Radiator fan wont run at high speed
do you mean high engine speed or fan speed.
if fan speed is slow then motor in the fan is getting bad.
if your talking about running engine, then could be nothing because the sensor tell it not to..like running down the road it cools the car down and engine temp drops slightly enough to cut sensor off.
Apr 22, 2011 | 1999 Oldsmobile Intrigue
I have a Sherwood PD - 913 R and the pitch seems to be spinning out of sync which makes the RPM"s not right for 33 or 45 speeds, any help on what could be the cause is appreciated. There is a pitch...
The turntable motor might be the problem, if the grease is old it becomes hard causing the turntable to run slow, by your description we can rule that out since you indicate it runs to fast. therefore it is the voltage that powers the motor with a regulator "keeps voltage constant" or the motor itself will be the problem. The pitch control allows a small change in speed when required.
Dec 30, 2010 | Audio Players & Recorders
Turntable speed
There is no pitch control on this unit.
Apr 03, 2009 | Intellitouch Communications INTELLITOUCH...
Sony TC 530 tape speed problem
If it's slightly faster than normal, that's fine. You'll just need to check the rollers and tighten them slightly as well. They might be loose or sort of that.
Dec 26, 2008 | Quantegy 456 Reel-To-Reel Recording Tape
Technics SL-1200MK2 Turntable Logo
232 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
