Roxio Easy VHS to DVD for PC Logo
Posted on Feb 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im having problems installing from disk. is there another option wehere i can download the latest version
Lewis Fulkerson
Level 2:
Scholar:
  • Expert 69 Answers
  • Posted on Feb 13, 2010
Lewis Fulkerson
Expert
Level 2:
Scholar:
Answers
69
Questions
0
Helped
22142
Points
195
Go to Roxio web site, and check with their support or customer service dept. They should be able to get you a downloaded version.
Give the instruction i already download d3dx9_26.dll and i already download direct x but still did not play help me by practices
If you installed the relevant dll from a 3rd party site, uninstall it. The appropriate dll may be included on the installation disk. If it is not, you will want to install the latest version of DirectX. Sometimes, Microsoft does not number such versions. Regardless, if you do not find it on the installation disk, get the latest DirectX version from the Microsoft site. Choose to install it from SAFE MODE. If this does not work, try uninstalling and reinstalling the game or program. If that does not work, you might try updating the video card drivers. The freeware program Speccy should identify the video card. Usually, you go to the primary device's (laptop manufacturer's) website for driver, rather than using 3rd party driver installers. Note that the most compatible dll version is likely on the installation disk. Any changes in installation may not be recognized or registered until reboot. You can also try directly extracting the d3dx9_26.dll file individually from the latest DirectX package and installing it into your currently used version via Safe Mode.
1helpful
When i start mu pc i got failed to get proc adress for D3DPERF_Set options(d3d9.dll) Please help me to fix my problem Thanks
Try remove the skype IM from your system and download the latest version and install it again.
Yahoo Messenger IMs do not display TEXT, cannot read IMs. How do I solve this problem?
it will be better if you download a latest version of yahoo messenger and uninstall the previous version and install the new version of yahoo messenger., hope that will fix your problem.
8helpful
2answers
Error 7 keeps coming up when oppening itunes
A number of users have experienced problems updating to the newlyreleased iTunes 8.1.1. Generally, when this issue occurs, installationappears to proceed normally but then delivers the error message “Theinstaller encounted errors before iTunes could be configured. Yoursystem has not been modified. To retry these operations at a later timeplease return to the installer again. Click Finish to exit installer.”Fix
This problem can often be fixed by reinstalling the latest version of QuickTime via the following steps:
  1. Download the latest edition of QuickTime for Windows (make sure to pick the option without iTunes)
  2. Choose to save the file to your disk, then double-click the .exe file and install QuickTime
  3. After QuickTime is successfully installed, download iTunes again, choosing to save the file. Double-click the iTunes installer .exe and proceed with installation.
Other potential fixes for this issue include:
Run a disk check Disk errors, particularly in Windows XP, can prevent proper iTunes installation. See this Microsoft Knowledge Base article for instructions on performing a disk check/repair.
Use Windows Installer Cleanup Use the Windows Installer Cleanup toolto remove any references to Apple-related installation files(QuickTime, iTunes, etc.), then re-try using the aforementionedtwo-step method to reinstall QuickTime and iTunes
3helpful
My blackberry keeps pressing keys by itself and pressing the enter key when im typing a message
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
2answers
No vedio
I just checked the apple site. To reset an iPod turn the on/off switch on and off and then hold down the menu and center button until you see the apple symbol. According to apple, that should reset it.
16helpful
5answers
My ipod is stuck in disk mode
Quick fix - press the menu & center button until the screen lights up or an apple logo appears. Then press the pause button until you can see the menu again.
Changed computers
I'm making an assumption that iTunes was working before on the other computer, and now that you have switched computers, the Nano is not being recognized by iTunes?
Try this, from Apple's website:
http://support.apple.com/kb/HT1339
Summary Learn how to restore iPod, iPod classic, iPod mini, and iPod nano to factory settings.
If you need to restore an iPod shuffle, click here.
Background It is important to understand the difference between "update" and "restore". Update simply installs the software that controls iPod and does not affect the songs and files stored on iPod's disk. Restore erases the iPod's disk and restores iPod to its original factory condition.
Warning: because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library. If you use the Nike + iPod Sport Kit, see this document for more information.
Products Affected iPod, iPod mini, iPod nano, iPod classic
How to restore iPod
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
2answers
Panasonic kx-mb781
Either go to driversguide.com or go to panasonic's website and request the latest operating specific driver for your Panasonic kx-mb781 scanner. Download the driver and install it. It may be necessary to uninstall the old driver first. Also, try to obtain the operating and maintenance manuals for the scanner from panasonic. If you don't already have it. If you spend a little time surfing the two suggested websites you should be able to resolve your problem. Get back with me if you still have problems.
Top Roxio Computers & Internet Experts
 Grubhead
Grubhead
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
