Question about Refrigerators
Lg frost free freeza ok fridge not getting cold looked at removable panel no cold air comming out of vents
  • 76 Answers
Well the first thing to think about is: Is it pluged in??? the second thing is that you should call a repair man to make sure the job is done right. Hope this helped. =)
Posted on Feb 25, 2008
I bought a hisense fridge a month ago, it was Ok when we connected just for couple of days, I turned the temperature up a bit so the freezer can be colder, but now
Hisense is a company that makes cheap budget end televisions. Sounds like the defrost timer may have failed. The cold is created at the rear of the freezer and cold air is vented to the fridge. Have it looked at under warranty.
Feb 02, 2017 | Frost Refrigerators
Freezer works ok fan works in freezer ok but. fridge is to hot. no air coming through vents
It is quite possible that your air vent from the freezer is blocked by frost and hence the fan is choked to give out any space for air. So put the fridge off and remove the freezer panels to inspect. If you notice frost in the cooling coils then you are sure that the auto defrost is not working.Allow time for the frost to clear, check the wiring to heater/ to the timer . Switch on and check for the timer to cut off or otherwise replace. If there was no frost and still the air was not blowing check the direction of the fan, if not clear the vent . Check also if there is any malfunction of the defrosting heater getting switched on, If so replace the relay/timer unit.
This can be the only reason but I expect you try this out and check accordingly. Good day.
Aug 03, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ref side not getting cold, freezer still cold
Hi, Is the Freezer still cold? If so either the Fan (In back of freezer-Remove rear panel) is not working or the vent between freezer and fridge is close (side panel between freezer and fridge) Check either of those should be able to pick which is not working
Jul 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer cold, fridge isnt. Vent issue. Please Help before thaw!
Is there any ice/snow whatsoever built-up on the rear panel of the freezer ????(very important to know this).
If so, you have a problem with the frost free part of your fridge,causing it to ice-up,
and blocking the air flow to the fridge section.
Repost, and we should be able to go from there.
Wigo.
Mar 04, 2010 | KitchenAid Refrigerators
Kenmore side by side, fridge not very cold 106.56249400
Hi: I hope I have the Information right. Since your freezer is working that means that your freezer is so full that you blocked the vents (not common,) or your defrost heater is out, or your defrost timer is bad. Since your fridge should be frostless it requires the vents to circulate air. Now that there is frost building behing the panel it blocks the air to your fresh food. If you are handy the defrost heater is at the bottom of the freezer behind the metal wall in the back (a coil in a glass tube) You can inspect if the filimant is broken replace the heater. The defrost timer can be mounted in various places , sometimes on a circuit board. Since it usually is the heater I wont go into detail. The good thing it's not the compressor. You can take a hair dryer to the metal panel in the back fo the freezer to check. If it is betond your expertise melting the frost that has collected back there will make the fridge work for another week or two. Until the frost builds back up again.Feel free to contact me again if you get it apart and have a question. I hope this helps, Jeff
Jun 02, 2009 | Kenmore 57029 Side by Side Refrigerator
Frost Free, freezer ok but fridge warm
If all else fails I would completely defrosted the unit.If there is any blockage this will open up all the tubes.Unplug it open the doors put pans of hot water in the freezer to speed up the process.
Make sure your fan is still working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refridgerater may be blocked.With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
Len West
Feb 16, 2009 | Westinghouse Refrigerators
Frost free fridge/freezer - not cold in fridge
The most common problem with refrigerators not cooling when the freezer cooling is the fan which supplies cold air to the freezer. Not easy to get to in most cases. Another problem is the vent to the fridge part is blocked or not operating with the adjustment control.
Nov 27, 2008 | Freezers
I have a zanussi fridge freezer combination, it is a frost free model, Im developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does...
Hello Mr Barnard
Welcome to fixya
You said, You have a zanussi fridge freezer combination, it is a frost free model, And you're developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does appear inside the fridge, it is 2years old.
Frost could mean a few things.
Is the freezer cold but the fridge not?
If so the freezer may be so full that the articles are covering the air vents in the back that share the cold air with the fridge.
I've have seen the freezers packed to the hilt!
More things to check.
Is the condenser in the back or under the front of the fridge. If it is under the front of the fridge you must remove the plastic grill`(The condenser is the thin black metal tubing that runs back and forth to make up your condenser). This needs to be free of dust and have air passing over and through it!
they sell refrigerator brushes for this at the hardware store.
I have had customers that never ran the brush under there ever and had 1 to 2 inches of dust and lint
under there between the tubes.After a few hours it was cool the next day it was cold!
The freon level pressure should be checked in case you have a leak.
The thermostat may be bad.
Let me know what works for you.
Huuum
Please remember to leave a rating!
Oct 05, 2008 | Refrigerators
Freezer not freezing enough and fridge not cold enough
Hello Scott, remove the food from the freezer side and remove the rear freezer panel. You will see a coil and it should be completely frosted over. If not then you have a sealed system issue. If it is froze solid in frost where you cannot even see the coil, then you have a defrost issue. You should have a little frost on all the coil, the defrost is what clears the frost so the evap fan motor can circulate the air thru out the unit. If frost is good, push the light door switch to start the fan. If it isn't running check for 120 volts. If it has voltage, but not running, replace the motor. Hope this helps.
Aug 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Jenn-Air JFC2089HES (French Door) Fridge not cooling enough
Hey Northrock,
Did you ever get your fridge fixed? I have the exact same fridge and the exact same problem.
Nov 22, 2007 | Refrigerators
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
