PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Pioneer dvd-rw dvr-k17 problem
By phillipp on Feb 25, 2008
I have VGN FZ290 (sony customized model notebook). Now the problem is that it show no dvd drive on MyComputer but shows yellow triangle on Device Manager as"YX3808M SVO066H SCSI CdRom Device".
OS is vista premium
pioneer dvd-rw dvr-k17 ata
Please assist how to fix the problem. The drive was working properly before
Thankyou in Advance
i have a sony vgn-fe855e laptop and my dvd-rw drive won't show in my computer. the device manager shows pioneer dvd-rw dvr-k17 ata device with a yellow triangle and an exclamation point. what should i do? i tried reinstalling it but it keeps on telling me to contact the manufacturer.
Best Solution
posted on Feb 25, 2008
Helpful)
Sunil Panem
Rank: Wiz
Rating: 84%, 121 votes
Hi
Right click on the driver and then click Properties.
On the properties screen, check the device status and then go to the Details tab at the top.
If the details screen shows any errors or problems abt anything other than drivers, then follow the steps below to delete the upper and lower filters from registry.
Step 1: Back up the registry
  1. Click Start and and in the Start Search box type in REGEDIT and hit Enter .
  2. From the Registry Editor window, perform one of the following depending on the operating system:
Click File and then click Export File.
  1. The Export Registry File window will be displayed. Save In: should be set to the Desktop . Next to File Name: provide an easily identifiable filename like “Full Registry Backup”. In the Export Range portion of the window, make sure the radio button next to All is selected. Click Save to save an exported copy of the registry to the desktop.
  2. Step 2: Remove upper and lower filters
The steps below describe how to remove the drivers associated with the drives disappearing. After removing the filter driver keys, the CD recording software will be have to be re-installed.
  1. With a copy of the registry exported, click the plus signs [+] in front of the follow keys in the order they are listed: HKEY_LOCAL_MACHINE , SYSTEM , and then ControlSet . In some cases, multiple ControlSets may be listed similar to the following:
    • HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001 HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
    or
    • HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001 HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002
  2. Click the plus sign [+] in front of either CurrentControlSet or the lowest numbered ControlSet. For example, in the second list above, ControlSet001 would be the correct listing.
  3. Click the plus sign [+] in front of Control.
  4. Click the plus sign [+] in front of Control.
  5. Click the plus sign [+] in front of Class.
  6. Locate the following key and highlight it in the left window of the Registry Editor (The numbers can be very similar, be careful select the correct key. Another method to find the correct key is to highlight Class, then cut and paste the key below into a Find window accessed from Edit and Find in the Registry Editor.)
    • {4D36E965-E325-11CE-BFC1-08002BE10318}
  7. With the key highlighted, the right pane will have multiple keys listed including LowerFilters and UpperFilters. Highlight LowerFilters and press the Delete (Del) on the keyboard. A confirmation dialog box will be displayed asking if the value should be deleted. Click Yes to delete the value.
  8. Repeat the process for the UpperFilters by highlighting UpperFilters, pressing the Delete (Del) key on the keyboard and again confirming the value should be deleted by clicking Yes.
  9. Exit the Registry Editor
  10. Restart the computer. The optical drives should then be recognized and available for use.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
Compurepair
Rank: Wiz
Rating: 84%, 786 votes
a yellow exclamation mark, is stating that the device has a problem.
this could be an incorrect or non-installed Driver.
Click or right click ( properties ) for further info on what the problem with the actual device is, or error code.
Mike @ compurepair.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area... (More)
Answer
error 163 173 ibm 600e laptop when turned on these errors occur
Answer
compaq laptop keeps restarting after being on about 3 - 5 seconds
Answer
Dvd drive wont work
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
