How the hell do you set a profile for this damn thing! Obviously you need a masters degree in game programming n order to use the rumblepad 2 from logitech. I don't have any connectivity issues, but I can't figure out the profiler. I'm trying to play left 4 dead 2 and during gameplay, the pad works, but it's like a special olympian in the NFL. left stick doesn't work at all, and none of the buttons fire a gun, on and on with problems. what's strange is after about 5 minutes of enfuriating game play, the button format completely changed on its own! all of a sudden the d pad stopped working and the left stick controlled movement., although couldn't turn/rotate the player with any of the buttons ever. Any body have one of the these worthless controllers? I paid 40 bucks for the damn thing, I'd at least like to use it once before I blow it up with some C4. Also, pardon the typing errors, my RF keyboard is deciding to **** out on me too! AARRRGGGgHHH!!!!
Take it easy bro everyone is having that problem. But I am the doctor, i know how to make proper profiles I can help you out. What game do you need a profile for? Let me know I will try my best to help you.
please check that the oven isn't leaking heat into another area. Or maybe your settings need some calibration or the temperature sensor for the oven is off by 60 degrees. If this is the case, changing the temperature setting to 410 should bring the internal temperature to 350 degrees. Please try this.
I don't think it entirely fair to say "any degree provides these" and then list quantum physics (which is most likely above bachelor degree) and computer science as examples. Obviously if they can solve "high level problems" they can think critically. But if we take a physics degree for example sure it might seem more prestigious but most people will not find jobs in physics with out at least a masters and that's if your lucky. In both cases the degree does not provide the exact skills used in a job but that does not mean the degree is useless.
If you are using an external hard drive you should go into settings then memory to format it because it is the safest way of storing data on your external hard drive and if the games or apps you have on it load you are fine.
If you are using the hard drive built into the xbox 360 it should be the same kind of thing. Games load, profiles load all the kind of stuff. but you don't need to format the internal obviously.
One thing you could check would be to check the dates of saves put on the hard drive or updates. To do this just go into settings then memory and go into your hard drive and open any game in hard drive and check the dates and see if they make sense
The games I am trying to play are Left 4 Dead 2 and Batman Arkham Asylum.
