If you hear a buzz noise coming from the back when you press the pad for water it most likely is a bad water valve.
If you hear nothing you have a bad micro-switch or open solenoid on water valve(again bad water valve)
To check a few other things, unscrew the tubing on the side that is sending water to the door(dual valve in back) see if water comes out when pressing door pad(need a towel and leave unplugged until ready to test)
If there is water you may have a frozen tube assembly in the lower back of the refrigerator section(coil pack of plastic that chills water) or unhook at the door on the bottom of the freezer being careful not to bend and see if water is there.(have also seen tubes freeze up in door liner. Most common is a bad water valve.......
Replace the water valve on the back
SOURCE: Frigidaire side by side MRS22WNGD0 stopped dispensing ice and water
Even you find the problem you should need special equipment.Better call a technician.This link may help you:
http://www.appliance-parts-warehouse.com/frigidaire-parts/Frigidaire-Refrigerator-Parts/Frigidaire-Parts-MRS22WNGD0.cfm
SOURCE: Kenmore Side by Side Fridge - Ice maker/water dispenser
we got to chat about this so hold my rating till we are don how is your water hooked up house valve or self pericing saddle valve what kind of pipes do you have when you push the door dispensor do you hear any sound have you checked your filter
SOURCE: Kenmore side by side water dispenser has stopped
Most likely need to replace the water inlet valve. The water supply line should be directly connected to it. There are 2 valves bracketed together, 1 for the ice maker and 1 for the water dispencer. You will probably have to buy both valves, but want to do this anyway as the second valve will fail soon. Hope this helps.
