Question about Solis Palazzo Espresso Machine
Palazzo espresso machine
I'm having trouble removing the brewing unit. even when i move the lever over like the instruction say to. please help. thanks.
  • 2,039 Answers
You have to wiggle the unit some old coffee get in there it have to come wiggle it thanks for using fixya
pierre
Posted on Feb 25, 2008
How do you remove brew unit
I have done XP9000, this may be similar. Remove side cover, operate lever on side of exposed brew unit and pull brew unit out with the handle. You can only do this when machine is in normal 'at rest' position. Unit will not come out in any other position.
May 06, 2015 | Krups Ea9000 Barista Espresso Machine
Saeco incanto classic
http://www.partsguru.com/SaecoIncantoClassic.html
Apr 24, 2014 | Saeco Incanto Classic Espresso Machine
Solis palazzo not producing coffee
I think the blockage might be at the brew unit, remove unit and check the screen under the red o-ring, connected to that is the chute that leads to the espresso spout. That tube might be blocked, there are 2 screws holding that piece together, be careful when you remove them do not lose the spring and ball in the fitting. Clean tube and reassemble.
May 24, 2012 | Solis Palazzo Rapid Steam Palazzo Fully...
Solis Palazzo : turn on machine the brew group does not position it self to prepare coffee.powder coffee, coffee, and espresso lights blink. Brew group is not removable from machine. machine has had light...
Hi
This is for a Vienna but it should work for you Palazzo. It will help you get the brew group out and reset so you can reinsert it.
http://www.fixya.com/support/r2296970-brew_group_stuck_t_get_out
Aug 04, 2011 | Solis Palazzo Espresso Machine
The display indicates "brew unit
Remove brew unit and check lever for microswitch at the top back of the machine, the lever might be broken or the micro switch is damaged and cannot read the brew unit when it is inserted.
Apr 18, 2011 | Saeco Incanto Classic Espresso Machine
I removed my brewing unit to clean and now I'm having difficulty getting it to fit and snap in place. It will not go in all the way for some reason. I did the recommended restoring the unit back to...
The very top part of the brew group ( the part that looks like a square funnel) rotates very slighty. It must be in the slightly rotated position in order for the unit to slide in completely. So you need to look on the back of the brew group, there is a tab in a groove connecting the funnel to the base. slide that lever up or down (can't remember) then the brew group will slide in. Make sure you are NOT pressing the button you push to take it out. Just gently push the entire unit all the way back.
Hope this helps.
jkbell
Feb 16, 2011 | Solis Palazzo Espresso Machine
I have a Miele Coffee Machine (built-in) CVA 620-1. I got a message saying the brewing unit is blocked. I removed the waste unit, a procedure that has to be done before you can remove the brewing unit. ...
The brew unit has lose parts on left-hand-side, wiggle them up and down. Put the waste unit back, switch off the machine and then turn it on (pull the cord). It worked for me!!!
Sep 14, 2010 | Miele CVA615 Espresso Machine
I have a Solis Palazzo machine. My question is:
HI When was the last time you descaled? This can have a temp lowering effect if you don't descale on a regular basis. Program you water hardness so its set on 4. This will tell you when you have to descale. Descals is not the same as cleaning. Its a special acid that disolves the deposits inside the boiler.
Jul 24, 2010 | Solis Palazzo Espresso Machine
Insert Brew Unit
hi
If the brew unit (the dark gray thing inside that has "push" on it) is not locked in, you get this message.
Push in the center of the brew unit towards the back and see if you hear a click? If you don't, remove the brew unit and look in the back. Behind the brew unit there is a recess. Inside the recess is a verticle slot. There should be an arm the moves from top right to bottom left. If you don't see this arm, thats your problem. It will have to be serviced to replace the arm. Its caused by inserting the brew unit with the funnel down (not locked up). Remember to push the "Push" lever before inserting your brew unit.
Jan 01, 2010 | Saeco Incanto Classic Espresso Machine
Cleanded brew unit as instructed - brew unit miss error
check small switch behind brew unit in machine maybe your brew unit dont touch switch.
Aug 30, 2009 | Saeco Royal Digital Plus Coffee...
Solis Palazzo Espresso Machine Logo
54 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
