Question about iRobot Roomba Discovery SE Bagless Robotic Vacuum
Roomba discovery stop working
Hi,i dunno how my roomba just stopped workinh although i tried to change battery did all nice cleaning it doesnt seems to satrt.so sign of charging.it has been a year old im using.help .thanxs
  • 2 more comments
  • Anonymous Aug 31, 2008
    My Roomba Scheduler worked fine then suddenly quit working for no apparent reason. When I plug it in the power light starts up red then after a LONG time it changes to green. When the power light changes to green I have tried to use it but it dies after just a couple of minutes. I love this machine, and hope you have some suggestions!
    Thank you so much,
    Dianne
  • snjarrett Oct 31, 2008
    My Roomba was unplugged for about a month. Then when I tried to recharge and use, it dies after just running fo a couple minutes!
  • pdsalva
    pdsalva May 25, 2013
    need new battery
  • pdsalva
    sounds like need new battery
Try spraying a compressed air can (computer cleaner) under the brush compartment (under the yellow housing). There are sensors and other wires underneath.
Posted on Oct 12, 2008
Roomba Discovery SE Bagless Robotic Vacuum: My Roomba battery charger has no lights and does n...
use a multimeter to test if it is actually putting out a charge. Is this a regular roomba charger with the green led on top? And it just doesnt light up anymore? If so then the pack is dead. replace it.
May 16, 2010 | iRobot Roomba Discovery SE Bagless Robotic...
My roomba 400 series keeps stopping on its own
Take off the grill on the back of the bin. The round vacuum impeller is behind it. Make sure that's clean and free of debris. Run the Roomba with that little grill still off the bin-- is the impeller turning? If yes, you may have fixed it. If not, your Roomba needs a new vacuum bin.
Aug 26, 2009 | Roomba Robotic Floor Bagless Vacuum
When I push the clean button. (roomba discovery) it just makes a 'quack' sound and doesn't move.
the battery on your roomba is dead, try charging it for 16 hours, after that if it still does not work. you need to replace the battery.
Jul 12, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Keeps stopping.
your battery isn't holding a charge ,buy a new battery
Mar 25, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
IROBOT - CLEANED USING WATER - NOW DOESNT WORK AT ALL
you probably got the switches wet ,make sure all the water is out,then take a blow dryer to dry out the electronics
Feb 13, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Roomba discovery on full charge power up and it will run 5 sec power button then flashes red and roomba quits. I have tried removing battery and holding power button for 30 sec then charging same result
unfortunately the batteries on the roombas can go bad and not hold a charge and need to be replaced, also you should check all the brushes and wheels on the bottom, if they are bound up it would stop the roomba from working. the two brush rollers can be removed by pushing on the two tabs just above them, try and clean any hair from them. if its real bad you should buy the maintance kit from them witch gives you both brushes and filters as well.
Sep 16, 2008 | Vacuums
Roomba Discovery wiggles back and forth and turns over and over
No matter your model Roomba, this occurs when Roomba has gone "crazy." Its brain is no longer working properly and you can usually tell this when you've cleaned the dickens out of it a few times and the behavior is still the same. There's only one possible user fix and that is to take out the battery, hold down the power button for 20-30 seconds then reinsert the battery.
If that doesn't do the trick, IRobot might send you something called an Ozmo which you put in the data port to rewrite Roomba's brain. Unfortunately this requires it to be under warranty unless you get lucky. Good luck, all!
Jul 12, 2008 | Roomba Robotic Floor Bagless Vacuum
Roomba discovery
Cleaned the shaft that the spinning brushes are connected to. Used an eyeglass screwdriver to remove the brush.
Jun 18, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
Brushes not spinning....
My status light came on, the vac beeped twice and stopped. I noticed my brushes weren't spinning. I took an eyeglass screwdriver and took off the center screw that holds on the brushes. I cleaned the shaft that the brushes spin on. replaced brushes and it works great! I just did this now and it is still running. my status light problem is fixed my roomba is 4 years old and I am on my 2nd battery. Seems to have fixed the problem. FYI it was wrapped with hair, dirt and it was greasy.
May 29, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
iRobot Roomba Discovery SE Bagless Robotic Vacuum Logo
414 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
