After 2 years, more likely the caps will be bad by now, worst case will be bad lamps, open it up and look inside for caps with bulging top first, see example of failed monitors due to bad caps/lamps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Power Board ILPI-025 For LG W1934S & Viewsonic VG1930WM & Optiquest Q19WB & Acer AL1916W Ab etc
Model:ILPI-025 REV:E 79069140
bbarker4, If you typed your FIXYA problem using your pc and a known good swapped-in spare monitor, you know your pc is ok. So now you know VS11201 needs to be looked at. Use warranty if valid option!!! Go search ebay for any "Optiquest Q9 power supply" for sale. Look for that board inside your monitor and chcek to see if your board has any swollen, leaky vertical mounted aluminum can electrolytic filter capacitors on your Q9 "switch-mode-power-supply"/ "CCFL inverter board! Please note the brand name of the capacitors you find and let me know if you will be doing a DIY repair. 12fixlouie
