Question about RCA D52W136D 52 in. TV/DVD Combo
RCA D52W136D 52 in. TV/DVD Combo dvd does not play
RCA D52W136D 52 in. TV/DVD Combo does not play dvd/dvd does not load when you put the movies in.
  • 3 Answers
Did you try to get a dvd cleaner to clean out your dvd player.
Posted on Feb 14, 2010
SOURCE:
D52W136D
Common issue in this model---look to see if the option for convergence still appears in the menu---if not you have a bad part right at the flyback causing this---a kit of 3 parts is available (tvparts.com).
Set is also for this issue prone to bad solder connections at the flyback and right around it that will cause convergence issues.
Oct 29, 2012 | RCA D52W136D 52 in. TV/DVD Combo
Screen shows people with green shadows blurring screen 52 Inch RCA Projection TV
This is a common problem on this model. Call in a shop or do it yourself with parts and instructions from www.TvRepairKits.com
Apr 13, 2010 | RCA D52W136D 52 in. TV/DVD Combo
My tv turns on then off
Check the high voltage transister and flyback transformer.Also check cp114 and 120 for swelling.
Feb 10, 2010 | RCA D52W136D 52 in. TV/DVD Combo
When u push the power button the tv tries to turn on, makes 3 switch noises and then the power turns off
this is somtimes a bad power supply or fuse if you have sound it likly and no picture usaly a fuse put this seems pretty much like a power supply issue this regulates power from the wall to each component of the tv like the picture and the souns amp
Dec 20, 2009 | RCA D52W136D 52 in. TV/DVD Combo
Finding servicemanual
Hello plantain,
try www.servicemanuals.net or www.manualsparadise.com
Sep 09, 2008 | RCA D52W136D 52 in. TV/DVD Combo
RCA D52W136D 52 in. TV/DVD Wont turn on
Does the standby light flash in a set pattern? Some tv have a error code system which pinpoints the fault by flashing the standby light a certain number of times. Other than that my best guess would be a fault on the power supply or a fuse blown internally. Good luck.
Apr 08, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Dvd troble
some dvd players dont play all dvd. i think the dvd player dont support the format of your dvd movie try a different dvd movie.This msg show up in every dvd you try to play????
Dec 14, 2007 | RCA D52W135D 52 in. TV/DVD Combo
RCA D52W136D 52 in. TV/DVD Combo Logo
301 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
