WASHES BUT WILL NOT SPIN
HI I HAVE HAD MY MACHINE FOR NEARLY 7 YEARS AND NO BOTHER, BUT TODAY IT MANAGED TO DO ONE WASH COMPLETELY THEN WHEN SECOND WASH WAS PUT IN IT SEEMED TO WASH AS IN THE DRUM TURNED AROUND, TOOK POWDER ETC BUT FAILED TO DO FINAL SPIN AND JUST SAT DOING NOTHING UNTIL ITS TIME WAS UP - PLEASE HELP
Hoover 1200 will wash but will noy final dpin
    Genius:
  • 1,019 Answers
if it,s 7 years old. you,ve had your moneys worth. Scrap it and buy a new one.
as a repair solution, Check that the machine is emptying.
And that the pump has,nt got a coin/badge or anything else wedged in it.
Mike @ Compurepair.
Posted on Feb 25, 2008
Simpson eziset750 washing machine that washes but don't spin
Lid switch / drip dry botton on / wash/spin solenoid fried /
Aug 12, 2013 | Washing Machines
Spin cycle does not work. Machine only hums when it should spin.
Check the motor capacitors. Wash cycle and run cycle capacitors are different in some m/cs.If these are OK motor winding to be checked.
Now it is ten years old and you are likely to get ball bearing problem. Get an repair estimate and decide which suits your budget.
Apr 06, 2010 | GE WBSE3120B Top Load Washer
Oily substance collecting in the door's rubber seal.
It is not oil, but a build up of grease and living bacteria, caused by doing too many low temp washes.
The only permanent solution is to replace the door seal, and at least once a month, do a hot boil wash without clothes in, but with powder or detergent in as normal.
This is called a maintenance wash, and is now recommended by all manufactuers.
Please rate my solution.
Thanks.
May 13, 2009 | Bosch Washing Machines
I have as Bosch WFK 2200 washing machine, I can't get it to spin... Can you help please!?
Hi. If the machine is over 6 or seven years old it is possible that the wash motor brushes are worn out. Give me more info. FD number and number of washes per week.
0417362396 Melbourne metro area
Regards Sam
Dec 22, 2008 | Audiovox Bosch 718 World Cellular Phone
Kenmore wash machine will not spin
Eight years is getting kind of old. When the clutch or transmission goes out, it costs more to replace the part than to buy a new washing machine. You'd better plan a shopping trip rather than spring for that $100.
Aug 02, 2008 | Kenmore 22422 Top Load Washer
Indesit Prestige Line 822
i have this! 4 is a normal wash cycle 7 is a spin 5 an 6 seem to be quick washes an never tried 1 2 or 3!!! hope this helps!!
Jul 20, 2008 | Washing Machines
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
If your washer pumped out the water then your motor and water pump are both still working. Your washer has many sets seals and bearings that could have gone bad. This problem happened to my washer in the past also and i was able to just spin the drum around a few times and then shut the lid on the spin cycle. It started spinning slow but was able to make speed quickly. The oil seal on the gear case did start leaking though. This should be a cheap fix that could be done by most people with some mechanical ability.
Feb 14, 2008 | Washing Machines
W123 dispenser drawer keep melting
Hi there you can order the part from indesit and should not cost alot and yes it should withstand the temp check that if you are using the hot tap to the machine turn down the water thermostat as maybe too hot.
Thanks J
Feb 09, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
