Question about Olevia LT42HVi 42 in. LCD Television
Tv signal on and off
Ch 7 goes on and off. i use air antenna.
    Brigadier General:
  • 6,966 Answers
My post is based on the assumption that all other channels have no problem.
A couple of possibilities:
1. Aerial need re-orienting which involves re-directing for a better signal. This requires physically moving and adjusting the antenna to where it is pointed at;
2. RFI (radio frequency interference). There is a radio transmitter between you and Ch7's transmitter that overrides the Ch 7's signal. It would have to be transmitting very near Ch7's video frequency (170-180 MHz) or a harmonics. You could try reporting this to your government's agency charged with communication such as the FCC in the United States or NTC in the Philippines.
3. If all else fails, you may need to switch to cable.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 25, 2008
There is no signal on my emerson tv, how do i get one
1. You are not on the right input for the signaling device: Verify which input number (or type ie HDMI/component/video/Cable) your device is connecting to and tune to that input.
2. The signaling device is not powered on. Verify it is on and the cable is properly seated into device and TV.
3. The cable is bad. Try a different cable or use alternate type of connection.
4. The specific input port on the TV is bad. Move the connecting cable to a different port (ie from HDMI 1 to HDMI 2) and tune the TV to that input.
If you are using an Over the Air signal (OTA) with rabbit ears or and antenna use the TV menu to run an auto tuning scan of your local stations.
If you are using a tuning box (cable/satellite) over a coaxial connection check connections and tune the TV to CH 3 or CH 4 and check for picture. There may be a switch on the back of the box indicating CH 3 or CH 4.
Sep 18, 2017 | Emerson Televison & Video
How do I get back my local channels on my Vizio by rabbit ears
Make sure that you have the TV tuner set up to receive ATSC (digital) signals via "Off Air" or "Antenna". Having it set to the "Cable Ready" mode will only get you Ch 2 - 13. These settings are usually available in set up and may even allow the TV to scan for available channels, etc.
Jul 24, 2015 | Winegard RV-5095 Sensar II RV TV Antenna...
Shows "no signal" on my
when you say jack in antenna, I assume you mean you have an outide antenna. If you have never recived over the air signals before you won't now. If you have cable tv, then go into setup and set your scan channels to CATV and not Outside antenna, or what ever it might be called on your set. i need more infomation before I can give you more advice
Mar 17, 2011 | Televison & Video
I am tire of cable and want to use an antenna, I have hooked an antenna to the tv checked the hook up and it is secure, but am getting no signal...I have been trying to find a place to change from cable to...
After u hook up the antenna source like a digital or a roof antena to the tv.Used ur remote go into the tv menu.Goto SETUP,go down to CH.Pick AIR enter and scan for free air DTV channels.
Feb 25, 2011 | LG 32LG30 32 in. LCD HDTV
How to Chanel Scan
Tv is hook up to cable tv or free DTV air broadcasting?Have a good antenna source hook up or cable or satellite signals.Go into the tv menu go to SETUP.Go down to CH. press enter pick Cable or Air.Enter for scanning,after it done scanning will get all free DTV air or cable broadcasting channels stations signals.
Feb 08, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Why won't my new Vizio DTV work on an antenna without the digital box?
Do you have the antenna aimed correctly and the correct antenna for the distance between your location and the stations? Check antennaweb.org and tvfool.com for the directions to the stations you should be able to receive. Antennaweb assumes an external antenna and is very conservative in the station list. TVfool gives the stations you should get with various different types of antennas. Tall trees and buildings will block signal strength so consider the environment around you.
With digital signals, if you do not have enough signal strength for a given tuner, the channel will not come in. An amplifier may help you get the signal, particularly if the signal is shared to several devices. Failure of an amplifier or lightning surge protection can stop the signal from reaching the TV. A surge through the antenna can damage the tuner.
A damaged cable can also be a source of a problem. Check the outside portion of the wire as well as the interior wires. Replace any that have damaged insulation or ends.
For this TV, if you have done a channel scan with the TV set to the Input TV/DTV, and the Signal Source set to Antenna. Turn the antenna and then set the Additional Scan to On. (Menu > TV > Channels > Additional Scan.) Then do another channel scan.
If you need a copy of the manual, see: http://www.vizio.com/m220va.html#support .
Jan 22, 2011 | Vizio M220VA 22 in. LCD HDTV
After set up I did not get all the channels. I have 7 channels. To double check where does the digital antenna get plugged in on the television. I did not receive a book that explains the remote use...
After plug in the digital antena in the Ant. hole on the tv.Go into the tv Menu.Go to Menu SETUP.Go down to CH.Pick AIR,press enter,so tv will be rescanning to get all the DTV free air brocasting tv signals.
Aug 09, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Can a sabre tv model lct371bka decode digital signals? I have an air antenna and it can't seem to find any stations...
Buy a digital antena,Go in the menu go setup go down Ch.set up pick air not cable,go scan should have all free air channels.
Dec 29, 2009 | Sabre LCT371BKA LCD TV
I am getting a (weak or no signal)
Hello glc_11489,
Have you tried to use an amplified antenna? I have found that this works very well.
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Jun 12, 2009 | Philips Magnavox 20MT133S 20" TV
Olevia LT42HVi 42 in. LCD Television Logo
64 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
