Question about Brother MFC-9420CN All-In-One Laser Printer
Brother MFC 9420CN
With about 7000 copies run through, the quality of colour prints & copies have fallen off quite dramatically although gradually over a period of time with vertical lines just about visible on colour prints/copies.
The second lot of cassettes were recycled and I wonder if the quality of the toner is the problem?
Thanks Keith
  • ckmayeaux Nov 13, 2008
    I am having the same problem but am perplexed as to why you would download a lexmark driver can u explain?
    thanks
    christophr
    Scholar:
  • 69 Answers
Hi wensum....
i am vj_tech guy. plz download drivers n install them from the following site. select the operating system n start installing.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:582:0:0
Posted on Feb 25, 2008
I have a problem with print quality of my Brother printer mFC-6490CW, I have run the ink management utility, the black, yellow and magenta printed to about 95% just one dotted line missing on the black,...
Well, this is a common problem with people who purchase Brother printers, but do not always use Brother Ink Cartridges. Brother has a cleaning agent in the print cartridge and the compatibles do not.
"If you have a lack of one (or more) color do the following:
Make sure all carts are full, placed well and are secured. Insert a new ORIGINAL BROTHER CART for the one that shows no color.
Press menu then start bk-copy then four times arrow up quick after another. machine will switch into maintenance mode and all lights will flash. Press 7 then 6 then 4 then start bk-copy. machine will initialize the carts and refresh ink within tubes and print head. After that it does some power cleaning. When finished press 7 then 6 then 3 then start bk-copy. machine will run a power purge. when finished press 9 then 9 to leave the maintenance mode. do run a quality test print.
This should clean the lines out and clear up your issue.
Jun 20, 2011 | Brother MFC 6490CW InkJet Printer
If i have run out of cyan coloured toner, can i print only black somehow? the printer doesn't want to print at all (even on mono colour selection), and keeps asking to replace toner cartridge
There are few printers if any one toner ink is finished it does not print any more. So you must replace the toner or refill it then it will work.
Jun 12, 2010 | Brother MFC-9420CN All-In-One Laser...
The colour on my Brother 135C Printer is not printing properley, could it be that the printer heads need aligning? If so how do I do that? Regards, David Melton
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother DCP-135C Flatbed Digital MFC...
Black line 1cm in from margin when printing
this is a catridge problem so pls replace your printer catridge.
Aug 22, 2009 | Brother MFC-9420CN All-In-One Laser...
The Brother Network MFC-9420CN (Print, fax, copy and scan all in one) Error code ''k toner is missing''
Much pleasantly get acquainted. Yours colour cartrige soon ends - a warning, usually mines through 250. Thank you. Good luck!
Aug 19, 2009 | Office Equipment & Supplies
Mfc 9420Cn printing but marking black line on
try making a copy off of glass. if black mark is gone, then you have to clean the narrow strip of glass to the left of big glass.
hth,
razors
Apr 15, 2009 | Brother MFC-9420CN All-In-One Laser...
Printer is not printing clear and nice pictures
Dear Cubohr,
You need to check the other colour toners, if the other toners are running low, than you will find that the black tone becomes more prominant in your prints. Alternately, there may be an environmental condition with your unit. If it is in direct sunlight, then it is possable that you are getting light interference on all your prints. There are also a number of other reasons.
Check your toners first, check if there is light interference, if both are ok, your unit may still be under brother warranty and you may need to get it to a brother service centre.
Gremlin11
Dec 10, 2008 | Brother MFC-9420CN All-In-One Laser...
Colour ink runs out and can't print b&w page
with all brother printers all the ink cartridges must be full or the printer will not print brother tech
Oct 27, 2008 | Brother MFC-465CN InkJet Printer
Colour printing gives ghost image
Are you using genuine Brother color cartridges? If you are, then try different paper (20 pound laser printer paper or plain paper copier paper rather than inkjet paper,) Also, do not use recycled paper. If that does not work, you may need a new imaging (OPC belt) unit, or a new fuser assembly. Check your owners manual about when to replace the imaging unit or fuser. It is usually after 60, 000 prints have been run.
Jun 09, 2008 | Brother MFC-9420CN All-In-One Laser...
Fuser MFC 9420CN
The fuser replacement interval is 60,000 prints . The machine will print indefinately otherwise.The message is just a reminder.
Jun 03, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9420CN All-In-One Laser Printer Logo
175 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
