Question about Philips GoGear HDD6330 MP3 Player
Corrupt playlists The battery ran down and after recharging it I switched it on. Every playlist is corrupt. Entries display as [{[u*u7//]]676 . I managed to get the data off but it won't repair or allow me to format. Any suggestions? Thanks
  • 476 Answers
Connect the player to the power supply and PC.
Press and hold [Vol +] & [POWER] until player resets.
As soon as the screen goes blank, release [Vol +] & [POWER] and press and hold [Vol -].
Player should show the connection screen, but without the status line at the top
PC will recognise the player as a removable drive.
Once the PC says that the device is ready to use, open My Computer and player should be in the list. (GoGear)
Right click on the player and select format.
Tick the "Quick Format box" and make sure the format is FAT32, and click start.
When the player has formatted, safely remove, and power up. You will get an error message on the player saying "connect to PC".
Connect to PC normally and repair with Device Manager.
Posted on Feb 25, 2008
OK PEOPLE!! have asked this same question over and...am getting the run around...please don't make me continue asking for help with this question. its a sandisk mp3 mini clip, and this issue is getting any...
Use SanDisk MP3 Players
SanDisk is an electronic device manufacturer that creates various types of MP3 players under the SanDisk Sansa product line.
The SanDisk MP3 players range in storage capacity, starting at 512mb, and are intended to operate on the Windows operating system.
Most SanDisk MP3 players also include a built-in video player with a color screen, an FM radio tuner, and a memory flash card slot to expand the MP3 player's storage capacity.
Use SanDisk MP3 players to take your computer's MP3 library with you and listen to music wherever you go.
1. Verify that your computer meets the operating specifications required to sync the SanDisk MP3 player with the PC.
All SanDisk MP3 players require Windows XP or later; Windows Media Player; and a USB 1.0 port. A USB 2.0 is important if you want high-speed music syncing.
2, Check that the SanDisk MP3 player has a full battery charge.
All SanDisk MP3 players have a rechargeable lithium ion battery, and some SanDisk devices have a replaceable battery.
The battery icon on the top right-hand side of the SanDisk MP3 player's screen displays the current status of the battery's charge.
If the battery is low, recharge it before using the SanDisk player for the first time.
To charge, connect the player to your computer's powered USB port using the included USB cable.
The SanDisk player's screen will display a yellow charging icon.
Unplug when charging is complete.
3. To turn on the SanDisk MP3 player for the first time, unlock the "hold" switch on the top of the MP3 player by sliding it so that the orange tab does not appear.
Then, press the "power button" once.
Wait for the SanDisk MP3 player to respond.
The thumbweel of the player will flash a light and the screen will turn on to display the player's menu options.
Turn off the SanDisk player by holding down the player's power button for two seconds.
Wait for the screen to display "Goodbye" before releasing the button.
4. Practice resetting the SanDisk MP3 player to solve critical software errors and to fix the MP3 player if it freezes.
To reset the player, hold down the power button for fifteen seconds.
This resets the MP3 player to its original factory settings and can help resolve any problems you encounter while using the SanDisk MP3 player.
5. Connect the SanDisk MP3 player to your computer using the included USB cable.
Once the computer has sensed the connected device, the SanDisk player's screen will display "Connected" and the SanDisk Portable Media Player will be listed under Other in your computer's My Computer window.
6. Add music to the SanDisk MP3 player.
Double-click the Portable Media Player listed in the My Computer window.
Double-click the Music folder.
Select the MP3 files that you wish to load onto the MP3 player and drag them into the Music folder.
The player will load them into its internal memory and make them available for playback once the device is disconnected from the computer.
7. Sync your MP3 song playlists from Windows Media Player to the SanDisk MP3 player.
Create a playlist in Windows Media Player and connect the SanDisk MP3 player to your computer (see Step 5).
Once its connected, Windows will display a dialog box. In the box, click "Sync digital media files to this device."
In the next window, click Set Up Sync. In the menu, click Personal Playlists and then select the playlists that you wish to transfer to the SanDisk player.
Click the Add button then push the Finish button to transfer your Windows Media Player playlists to the MP3 player.
Aug 09, 2013 | SanDisk Clip Audio Players & Recorders
I have a slick 4gb mp418c-4. i have been trying to make use of the playlist files but can't seem to get it. how do i create playlists in my files?
How to make a Playlist --- Listen to the song you want to add to a Playlist. While the song is playing, press & HOLD the [MENU] button for a couple of seconds. Another screen will appear with the following options. 1. Music Playback -- Normal / Random 2. Select EQ 3. Lyric Display -- Enable / Off 4. Add to MyList 5. Delete the File Move to #4 and press the [SELECT] button. Playlists will appear. Choose which one you want to add songs to and press the [SELECT] button. A check-mark will appear, meaning song has been added to PlayList. Press [MENU] button to get out. To DELETE songs from PlayList --- Go to options list when you first enter Music file and scroll down to 'My Music List'. Press [SELECT] button, Highlight the PlayList you want to delete songs from and press [SELECT] button. Highlight the song you want to delete, press and HOLD the [MENU] button for the delete screen to appear. 2 options on that screen - OK & Cancel Hope this helps Andrew
Apr 29, 2011 | Audio Players & Recorders
Masterlink ml-9600
To delete a Track from a playlist, you must currently have that Track selected in the display. Pressing the DEL TRACK button will cause a confirm delete page to be displayed,where "Song 01" is the name of the Track to be deleted. Pressing UP/YES will remove that Track from the playlist, moving the next Track in the playlist in its place. Pressing DOWN/NO will cancel the operation and return the unit to its previous state.
NOTE: Deleting a Track from a playlist does not delete the audio samples from the hard disk. The audio remains on the disk in an "Audio File"
Jan 15, 2009 | Alesis MasterLink ML-9600
Downloading my music and then burning to a cd
Have you read the section of manual relating to 'Importing CDs' ?
Select a playlist, press 'playlist edit' - press HD/CD - insert CD, close drawer. Once Alesis has scanned disc, press 'track move' - display should read Move CDTrk -> Trknn where 'nn' is the next available track in playlist. Press Cursor Left to place cursor under CDTrk, press Down/No, and display should read Move CD->Playlist. If you now hit Yes it will copy all CD tracks to the active playlist (it'll prompt if the playlist isn#'t empty to make sure you want to add the CD to the tracks already in the playlist).
Once they are copied to the playlist, you can move them around if required, DSP them, then burn that playlist to a blank CD
Dec 02, 2008 | Alesis MasterLink ML-9600
Corrupt files
I feel that the problem you are having is because the firmware that is currently on the device is corrupted...i would recommend you to go to the sandisk website1.gif to get the latest firmware upgrafe for your device..the link for the firmware upgrade is below..I hope that helps...if you have any more problems please contact me....
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Please rate accordingly
Thank You
Computerrep
Apr 16, 2008 | SanDisk Sansa E280 MP3 Player
MP3 Playlist Problems
on page 26 of the manual it describes in detail how to save the playlist.
If this is not working the firmware may be corrupt and you will have to reload it
Mar 21, 2008 | RCA H125 MP3 Player
Archdfios 605 wi
mine's just gone a similar way - made a playlist and saved it...all songs were playing ok up until then. When i went to play the playlist it told me that the file was corrupt then proceeded to tell me all 14000 songs were corrupt...just in the middle of an attempted repair!
Jan 27, 2008 | Archos 605 WiFi Digital Media Player
We have a RCA H115A
Go through your list of songs loaded into your player. Highlight the song(s) that you want added to create a different playlist and hold the toggle down until you see "added to my Selections" (or something like that). Once you have selected your songs, go into the main page (titles, artists, albums, etc.) and select "playlists". You should see an option called my Selections/Favourites. Highlight and push the "menu" (m) button. Select Save playlist and name using the toggle up and down for each letter and over to work on the next one. Once you have saved and named the playlist. Return to my Selections/Favourites and delete to clear the list. Now you can create a new playlist....Now I just gotta figure out how to fix the System file corrupted problem on mine.
Nov 15, 2007 | Audio Players & Recorders
I have an mp3 player and i need help creating playlists and deleting
The below was copyed froma an earlier post of mine, read the bottom. Over a period of time your info can get corrupt from transering music back and forth. To format plug it in to usb. Go to my computer It shows up as a removably disc, usually drive f: Right click on drive f: (or the approriate drive) and click format. Let me know what happens, you will have reload the player, also try bypassing the software you are using to tranfer, by opening up drive f: and clicking and dragging your music into it , or you can copy and paste it into drive f: L8R Playlists can be created by puttung your music in separte folders within drive f:, each folder will show up as a playlist. Good Luck
Sep 17, 2007 | RCA Lyra RD2762 MP3 Player
Philips GoGear HDD6330 MP3 Player Logo
80 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
