Question about Philips DCP750
Looking for a new Install/Eject replacement part.
IPOD Connection piece is bent from improper removal. Is it possible to replace this or do I need to suck it up and buy a new DCP750?
  • 979 Answers
Contact the Apple folks to get a return authorization code and deal with the factory on this. Although higher priced than your local repair center, the job will be done by the folks that built the thing in the first place...accordianman
Posted on Feb 25, 2008
Ipod,touch,want,charge
There may be two reasons why the iPod will not charge.
1-the charging port may need to be replaced, look into where you hook up and see if there is any damage to the prongs within. There are very fine connections that lay on a hard plastic stub (charging port) if any pins are bent; out of place; or missing the connection would not be possible and will not get charged
2-the battery may need to be replaced. The battery sometimes dies and unable to recharge if you've allowed the battery to be exhausted completely before charging it.
Oct 23, 2013 | Apple iPod touch Second Gen (8 GB,...
Have a iPod touch 2nd Gen replaced a touch screen that did not work on the bottom of the screen. You could not get the space bar to work now with a new touch screen the side of it will not work ???
Either you have purchased a defective digitizer or the connection from the digitizer to the logic board are not contacting as they should be. Remove the new digitizer and check all the teeth (connections on both sides) and see if any are bent or missing.
Sep 29, 2013 | Apple iPod touch
What does code p1447 mean ...???
The code says "evap purge flow monitor fault"
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
This is a "jackpot" code. It points to so many possible causes as to be almost useless.
Feb 15, 2013 | 1996 Nissan Maxima
My new xbox keeps ejecting all the time. iv'e only had it for 4 months.
Do you have a custom faceplate on your system? If so, some after market plates have unshaved pieces of plastic that can push on the eject button. Another possibility is that your disc tray guide rails are clogged at the end and are not letting the tray close all of the way. That requires the system to be serviced.
Oct 28, 2010 | Microsoft Xbox 360 Console
The cassett will not eject. when I push eject button it says no
Got to love the factory stereo. I had this problem with my 1999 Taurus. I had to remove the stereo (use a pair of wire coat hanger pieces bent into a U shape and slide them into the holes on either side of the panel, you'll feel a click when you've aligned them correctly, then pull it out). Disconnect everything and use a set of jeweler's screwdrivers to take apart the tape player assembly. Bad news though, it sounds like the ejection action is bad. If you were planning on replacing the stereo with an after-market, now is the time to do it. You'll have better luck installing or having installed a new stereo.
Jul 01, 2009 | 1997 Mercury Sable
My question mark key does not work.
  1. The most common problem when faced with a non-working keyboard is an improper connection. Try reconnecting your keyboard, restart your computer and see if that fixes it.
  2. Turn off the system. Unplug the keyboard connect and inspect for any bent or broken pins. If the pins are bent, then it is possible to gently straighten them using the tip of a ball point pen or mechanical pencil. If the pins are broken, then replacement of the keyboard may be necessary.
  3. Try updating the device drive
Jun 25, 2009 | Toshiba Satellite A135-S2386 Notebook...
Bose docking station chip broke off
I had the same problem that the ipod would onl play when I pulled it forward in the dock. Looking closely, I saw that some of the pins on the left hand side of the connector were bent forward, so I bent them back with a needle:
(ie. pushing the pins to the right, as shown here). This solved the problem for me.
If your connector is too far gone, I suggest looking to:
http://www.chargeconverter.com/shop/connector.htm
for a new connector for £3-4 or
for a whole PCB (Printed Circuit Board) replacement for £10-15.
Hope this helps...
Nov 26, 2008 | Bose SoundDock digital music system...
The bottom part of my ipod is bent
so basicly the bottom connector is broke. possibly the whole mainboard would need to be replaced or simply the connector replaced
Apple repairs
https://selfsolve.apple.com/GetWarranty.do
Some tech might replace the parts for 40-60usd. I cant say for sure since I dont know how bad it is.
Apr 27, 2008 | Apple iPod MA446LL/A MP3 Player
A4 TECH RFK-25 KEYBOARD
Please try below steps:
3. Try updating the device driver. Visit the manufactures web site for the latest driver available for your keyboard make and model. While at the manufactures web site. See if there are software patches or updates available for your keyboard. If there are, go ahead and install them as well as the updated driver.
4. If you are using a multi-media type keyboard, be sure to delete the software before installing any new drivers for this type of keyboard. Install the updated driver for the manufactures web site, then re-install the keyboard software. If any software updates or patches are available for your multi-media keyboard, install them at this time. Delete the keyboard software by using Add/Remove Programs (Start>> Control Panel>> Add/Remove Programs). If you receive a prompt asking if you would like to remove all shared files, answer "No to all". Then click OK.
Further steps on this issue:
Disconnect the keyboard from the computer and connect another known working keyboard to it. If this is a PS/2 keyboard and connecting multiple keyboards or a known working keyboard to the computer PS/2 port does not work unfortunately it's likely that the PS/2 port is bad. Because this port is part of the motherboard this will require that you replace the motherboard.
Alternatively if replacing the motherboard is too costly or not an effective solution you could also consider using a USB keyboard if USB ports are available on the computer.
I hope this should resolve the issue.
You can mail me at thumuvikram@rediffmail.com for any further assistance.
Bye.
Oct 17, 2007 | Compaq Keyboard
Philips DCP750 Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
