Question about Vacuums
My Bissel 12 amp carpet cleaner will not dispense water when I push down on the button on the handle.I thoughly cleaned the machine it sucks water up but doesnot disperse
  • leilaswahn Feb 25, 2008
    What do you mean the water pusher needs to change??explain further thanks
    Sergeant:
    Champion:
  • 281 Answers
The water pusher needs to change.
Posted on Feb 25, 2008
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
Tip
Bissel Carpet Cleaner Won't Dispense Water
"My Bissel carpet cleaner has little to no spray action".
This is a common problem and here are some Trouble Shooting solutions. If your machine is only dispensing a little bit of water, or none at all, then:
1. The bladder may be empty- Turn power off, remove tank and refill.
2. The lent screen may be clogged- Clean out the lent screen.
3. Tank-In-Tank may not be seated properly- Turn power off; remove tank and reseat tank.
4. The pump belt may be broken- If so, replace with a new one. The belt can usually be accessed through a belt access door on the top-side of your machine.
Here is a Link that will help in your search for the right belt:
vacuumcleanershop.com/
Good Luck!
If you should have any questions about"Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power- HAND TOOLS" at FixYa.com
I will do my best to answer your questions about drywall finishing. However, it would be best if we could speak on the PHONE or do a live CHAT. I can answer any question you have if it involves getting a wall ready for paint!
Thanks for looking,
Jim
Key Words: Carpet Cleaning, Rug, Steamer, & Stains
on Oct 08, 2010 | Vacuums
Hoover carpet cleaner does not **** water it blows
push the little square thingy down on the very front of the bottom bucket, then put the lid on before you put it on the machine, then let the force of putting it together push the front thingy up when you put the bottom bucket on the machine as one assembly..... it makes the seal right somehow..... ....my wife about pulled her hair out before we figured it out the hard way...... I may get a reward tonight......
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I need instructions on how to use my machine. Can you please help!
if its a bissell,go to bissel .com and request a manual sent to you.there should b a cartridge that you push a button to unlock so u can fill it with water or carpet shampoo.I fill mine half water half carpet shampoo. then u put it back on ,make sure it either clicks or snaps on.plug in and turn on,they usually have a button that turns that say wash or rinse.it depends on your machine.
Jan 19, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Whare does the dirty water go in the bissel 12 amp pro heat carpet cleaner
the clean water goes into a "Bladder Bag" that is located inside the tank. The way it is designed to work, as the clean water dispenses from the bladder bag, the outer part around the bladder bag fills with the dirty water. It never touches the clean water. Seems wierd, but it works! I hope this helps, if it does, please give feedback, as it helps me to gain ratings. Thank you! Remember to have your cleaners serviced every year by a qualified tech! Rene (The Vacuum Doctor)
Nov 06, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell carpet cleaner model #1697-W will not dispense the cleaning solution and will not **** the water back up--also need to know how you get to the belt on the machine?
The drive belt for the pump is located under a cover on the front right side as you look for the front of the machine. Just lift it up and the belt will be obvious. If it is not sucking then make sure that the dirty water tank is empty and that all the filters are clean and the front of the machine is not clogged with fibres, dirt or hair. Also check pre and post motor filters and clean them if required. Then check the mix control is working OK to allow fluid to flow out of the machine and not switched off. Bissell's are simple machines.
Oct 06, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissel proheat is not sucking up water
There is a oblong black seal that sits where the tank lip and the clear noozle window come together, is it there. Also make sure the filter in the tank lid is clean.
Jul 09, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
144 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
