Question about Alpine CDA-9813 CD Player
Cda 9813 alpine say ERROR
Have a CDA9813 as well, and mine has the same problem. When I turn on the ignition in my vehicle, sometimes the unit works, and sometimes it doesn't, even though all the buttons and display light up as normal. Plus whenever that happens, the CD will not eject. I need to turn the ignition on and off to get it to work. I have not gotten an error message yet.
  • 7 more comments
  • alberto mora
    alberto mora Feb 25, 2008
    and if is the reader, when i have this problem why dont eject the disc and why i cant listen the radio?
    I need to change , clean or what with the reader?
  • alberto mora
    another expert say , the problem is the READER,,,how do u think=? tomorrow im try with ur solution. have some diagram for this unit, because last night Im open the unit to eject the CD inside, and when im pull the CD , and now i have a one extra piece!!!
  • alberto mora
    when can i get this one?
  • alberto mora
    i mean Where?
  • alberto mora
    im try to take a pic, but its to little., but is like a little shock,
  • alberto mora
    alberto mora Feb 28, 2008
    extra pieces...DONE. But i have the same last problem, im try to put the acc wire in battery and is exactly the same problem, any other solution?
  • alberto mora
    nice solution...better tell me taht i have to buy another one. Thanks ur solution was funny anyway
  • alberto mora
    alberto mora Feb 29, 2008
    hi, yes i reset the stereo, but its exactly the same problem, and my vehicle is a ford f150 extended cab
  • alberto mora
    well, just let me try , i will do this, by the night, know some atorized alpine dealer o alpine service in el paso texas Usa? Im to 3.5 hours of El Paso.
    May be i can record a little video of my problem and upload to you tube
    Brigadier General:
  • 6,966 Answers
Initially, it may not be the Alpine CDA9813's fault. It is possible that the electronics/electrical of your vehicle is causing false readings to the logic circuitry of the Alpine unit. This could be as simple as your ignition switch (which could be corrected with a spray of electrical contact cleaner) to loose shielding/grounding in your EFI.
Try hooking up the Acc wire of the Alpine direct to the battery B+. This would in effect make your unit work even if the Ign is OFF. If problem is gone them it is your vehicle's electrical/electronics messing up the Alpine. if problem persist then it is the Alpine unit really in question.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 25, 2008
  • 4 more comments
  • Louie  Role
    Louie Role Feb 25, 2008
    Missed adding, it could be a matter of loose connection. There are 3 important wires needed by the unit aside from the speaker wires. they are: 1) the main B+12 that goes to the battery terminal + pole; 2) the ground wire which of course goes to the chassis ground and the 3) ACC wire which switches the Alpine unit ON/OFF.
  • Louie  Role
    Can you post image of the "extra piece"?
  • Louie  Role
    Louie Role Feb 29, 2008
    Hi again,
    Have you tried a reset? Most Alpines have a tiny recessed reset button.
    By any chance is your vehicle a Dodge (Durango or mini-van)?
  • Louie  Role
    The reason for my asking the vehicle was that there were some reports the electronics of the some vehicle affects Alpine 98XX series. One workaround was to reset the vehicles electronics by disconnecting temporarily the battery's B+12 terminal ( and others included all the fuses). There were accounts of successful results but most are with Dodge vehicles. Am not sure if it would do the same for you considering yours being a Ford.
  • Louie  Role
    Louie Role Mar 01, 2008
    sorry no. I live across the globe. Perhaps you can try a Google for "Alpine Car Stereo Service El Paso".
  • Louie  Role
    a friendly warning. there are some stereo units that go to a protective mode when the vehicle's battery is removed. You would need a code (or a special CD) to reactivate.
    Sergeant:
    Champion:
  • 281 Answers
The problem is with the reader.
  • Ivo Dicarlo Feb 25, 2008
    you need to exchange it
Alpine cda-9813 no power
You check the radio fuse in the fuse panel?The wire connections are right? Check the Owners Manual for other details or troubleshooting: ALPINE CDA-9813
Hope helps.
Jan 29, 2010 | Alpine CDA-9813 CD Player
CDA-9813 No sound, will not eject CD
There is a very tiny dot located either on the actual face of the alpine head unit or on the front plate of the radio once the face has been removed. Once you find this dot(if on the actual face) you need to make sure unit has power turned on and witha tiny needle or pick you may push this reset buton in for about 2 seconds. The face will automaticaly fold down and the disk will eject itself. Once this is done do not place the same disk back into the unit. Hope this solves your problem
Jun 09, 2009 | Alpine CDA-9813 CD Player
ALPINE CDA 9813
make sure that the acc and ground are hooked up right. acc has to be 12v. if you hooked it up to any other wire it will work until you(turn it up) draw more power than the wire you have it connected to can produce. or you have speakers that are faulty or too big for the alpine head unit.
Sep 18, 2008 | Alpine CDA-9813 CD Player
Alpine 9813
i have that same problem. when i turn the volume up, it shuts off but comes back on right away. the only thing i can think of is i'm not running the constant power directly from the positive terminal on the battery (which is what is recommended). not sure if thats the solution but im gonna try and wire it right anyway...
Jul 19, 2008 | Alpine CDA-9813 CD Player
Don't know how to display clock on Alpine CDA9813
i think the clock is on the disp button in the top left
Feb 15, 2008 | Alpine CDA9812RB CD Player
No Sound
everybody here got took by alpine. get together form a class action suit.
Jan 07, 2008 | Alpine CDA-9813 CD Player
Alpine CDA-9813 CD Player Logo
197 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
