Question about Toshiba 61H70 61" Rear Projection Television
Need Blue Lamp
I'm looking for the blue lamp, part no P16LTX10, for my Toshiba Theaterview 61H70 TV. Can somebody give me a lead on where I can order it in Asia? Would appreciate any reply to jose_escay@yahoo.com.
Many thanks,
Jose R. Escay
  • 76 Answers
I would think you would have to get one in America most likely at bestbuy or Circuit City. Hope this helps. =)
Posted on Feb 25, 2008
Hi all. i got 1 toshiba led tv 32pb10e problem DOUBLE IMAGE WITH DISPLAYED RED N BLUE COLOR ONLY ON SCREEN . I TRIED REPAIRED SINCE LAST NIGHT BUT CANT . PLS HELP ME IM URGENTLY NEED REPAIR IT . TQVM
The old projector TV's are using 3 lamps for Red Green Blue....in your case the Green lamp stopped working....either the Green lamp burned or the lamp board is defective.
Mar 31, 2016 | Toshiba Televison & Video
Toshiba 56hm66, lamp replaced but lights still blink
Check the circuit boards to see if any have failed. They are small cylindrical objects. If the tops of any of these are bulged instead of flat then they are bad and board will have to be replaced. Hope this helps.
Jan 03, 2014 | Televison & Video
I believe the blue lamp in my 57H81 is going bad.
You need to replace convergence out chips in your Toshiba 57H81 tv by qualified tech because 3-D look picture in rear projection tv shows some thing wrong with convergence output chips.
Your tv model number shows it is rear projection tv that use 3 tubes to make color picture on front screen where as dlp tv use one lamp as back light source to present picture at front screen that is generated in light engine.
Mar 25, 2010 | Toshiba 57H81 57" Rear Projection...
How do I know I need a new projection lamp? My tv
This set does not have a lamp. It has 3 crt tubes that converge to create a color picture. The convergance is off a little causeing this affect. Go into the menu and look for convergence or magic focus. You can download the owners manual from Toshiba website to do this. You will need the remote that came with the set.
Nov 30, 2009 | Toshiba 50H82 50" Rear Projection...
Tv no picture 50vf820 red blue lights on?
Yes you should order a new lamp and replace it. if you are not real handy with tideous electronic tasks, consider buying the lamp in am enclosure for an additional $30
Apr 29, 2009 | Hitachi 50VF820 Projection TV
Toshiba 61H70
Does it look like a 3D image?
Would you be able to post a picture of the TV with the mention lines?
Aug 16, 2008 | Toshiba 61H70 61" Rear Projection...
TV WILL NOT TURN OFF
Greeting inmiltown,
It sounds like your approaching the end of your lamp's life. Most projection televisions have internal lamp timers. These lamp timers usually give you time to buy a new bulb before it needs to be replaced.
I hope this helps.
Jon
Go Ahead. Use Us.
Apr 24, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Apr 21, 2008 | JVC HD-52Z575 52" Rear Projection...
No Picture
Was the lamp replaced? They're not always shattered inside...Sometimes they look ok and are defective.
Nov 27, 2007 | Toshiba 52HMX84 52" Rear Projection...
Open Questions:
Toshiba 61h70 Picture Problems Hello, I have a Toshiba 61h70 TheaterView HD Projection TV, and was recently having some slight convergence issues (red was out of alignment and could not be adjusted). So I researched and found that the IC?s (STK392-110) needed to be replaced. I initially purchased them on eBay, to later find out that they were cheap clones and did not work (they made the convergence worse, actually). I then purchased 100% Sanyo IC?s from a reputable dealer and replaced the IC?s again. Once finished, I then entered the service menu and adjusted the convergence alignment. Once the alignment was perfect, I hooked back up the TV antenna, the DVD player (composite), and the S-video from my computer. The convergence is fine, but now I?m having a totally different issue ? the video is ?scrolling?. The menus will show up fine, however any incoming video inputs will show up okay for a split-second, but will then flash and the picture starts to scroll in different directions. This happens with any of the video inputs. I checked and changed all the service menu items to factory defaults, however this had no effect. I have pasted a link below to a short video that illustrates the issue that I?m having. Please note that the video starts off with a black screen, showing the ?input? menu, and then I selected the ?TV input? and changed the channels. You will see the picture fine for a moment when the channel is first changed, but then the picture will start to scroll. Any ideas of what would be causing this? And how can I correct the issue? I?m not a TV repair expert, so I?m not even sure where to start. Any help would be greatly appreciated. http://s75.photobucket.com/albums/i303/hybrydmike/?action=view₪t=TV_Troubles.flv
Feb 27, 2017 | Toshiba 61H70 61" Rear Projection...
Toshiba 61H70 61" Rear Projection Television Logo
104 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
