Question about O2 Xda IIi Smartphone
Touch screen irresponsive
I have an O2 XDA IIi Pocket PC. The touch screen is not responsive even after soft and hard reset. This happened after a pen-stylus was pushed down too deep into the stylus slot and tilted the upper case slightly opened. It is properly closed now.
I really like this PDA and wonder if anyone/company has an idea how to fix/repair it.
Chip
Ann Arbor, Michigan
  • shajunaid Dec 22, 2008
    touch screen not responding at all! O2 Xda Mini
    Genius:
  • 1,019 Answers
You,ve probably dislodged a wire on the actual screen, with the stylus, and the screen lifting.
There will be several companys, willing to repair this. But at a costly sum i,d imagine. if it,s warranted, or covered on insurance ( home or personnal ) i,d try that option.
Most repair specialists, Will tell you that you,ve damaged the unit and need a replacement screen, regardless of whether you do or not.
Try a local Mobile Phone repair specialist, this may be your best and cost effective Option.
Mike @ compurepair.
Posted on Feb 25, 2008
Touch pad is not working.
Go into Settings > Personal > Input
Down the bottom it should say "If stylus taps become inaccurate, align the touch screen."
Click on the word "align" that should be blue.
Jul 13, 2010 | O2 Xda IIs Pocket PC
Haii have a touch screen problem with my o2 xda atom.there is no responses when i touch the screenbut the screen looks fine.i have tried bought new lcd and get installedunfortunately the screen fail 2...
More than likely, the small ribbon cable that goes between the touch matrix and the connector on the mainboard is damaged. Ether the ribbon cable, or the connector(s) itself.
Jun 23, 2010 | O2 Xda Atom Exec Smartphone
My o2 goes to hard reset when press button to unlock
http://xda.o2.co.uk/pdf/user_manual/Detailed_XdaIIs_Windows_Userguide.pdf
Mar 15, 2010 | O2 Xda IIs Pocket PC
How to hard reset my o2 xda II?
To perform a full reset
A full device reset clears memory, deletes all data, and restores the Pocket PC Phone to its default settings. Programs installed at the factory remain. All data that you have created and programs you have installed are erased.
Press and hold the Power button, and then use your stylus to press the “soft reset button” at the same time. Be sure you have backed up all your data on an SD card or on a desktop PC before performing a full reset. Hope this helps.
Jun 26, 2009 | O2 Xda IIs Pocket PC
Broken screen (o2 Xda IIs)
Try Ebay. I had a phone once that I broke the screen and went to ebay. I typed in the exact model # and looked fror touch screens. I found one and got it and replaced it and it worked fine.
Jun 22, 2009 | O2 Xda IIs Pocket PC
How to hard reset my o2 xda IIs
Hi...dis is prakash...see dear you can make hard reset of your phone by using this method
press and hold power and cemera key and soft reset button ..I have HTC touch its working ..I hope it will work on your phone also..further u can contact throuh my mail - jhunjhunda_123@rediffmail.com
May 12, 2009 | O2 Xda IIs Pocket PC
O2 xda formatting
Quite possible the upgrade failed and has corrupted something.
You will need to find out how to perform a Cold reset as this should return it back to factory defaults.
See here for some assistance.
http://www.pocketpcaddict.com/forums/pocket-pc-tips/14964-how-hard-reset-your-pocket-pc.html
Apr 24, 2008 | O2 Xda IIs Pocket PC
XDA II pocket PC manual
can download pdf version from the following link: xda.o2.co.uk/downloads/Detailed_XdaIIs_Windows_Userguide.pdf
Sep 17, 2007 | O2 Xda IIs Pocket PC
Touch Screen Damaged
To some degree you can use the control buttons on the device but you will be limited to what you can do. I suspect you will find the device impractical to use without the stylus.
Feb 14, 2007 | O2 Xda IIs Pocket PC
O2 Xda IIi Smartphone Logo
184 people viewed this question
Top O2 Computers & Internet Experts
zurysk8
Level 1 Expert
xxxxxx xxx
Jax Planet
Jax Planet
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
