i am the only administrator of my pc......some virus have affected my pc.i have removed it successfully..but my hidden files are not visible after that.i am using windows xp ,..sp2 .. please help ............thanks
12 Other Users Have The Same Problem
Comment by mohin, posted on Jul 15, 2008
I open foldr option and select to show all files. but hidden files r not showing
Comment by Guest, posted on Jul 14, 2008
hidden files are not visible problem
Comment by Guest, posted on Jul 12, 2008
hidden folders not visible
Comment by Guest, posted on Jul 08, 2008
same here , when i opent "folder options" and want to view my hidden files, it just getting back to the deafult setting. I can't view my Hidden files....
Comment by manojnirala, posted on Jul 07, 2008
Hidden files are not visible problem, and notify me when a new solution is
this is possibly just a settings error.
1:) open any folder on the desktop.
2:) At the top of the folder, select-Tools.
3:) Then Folder options.
4:) Then Select View.
5:) Then you,ll see Hidden folders And Files.
6:) check the Box ( Show hidden files And Folders ) if the Do-Not Button is ticked/Checked.
Hope this Helps.
mike @ compurepair.
Was this solution helpful? Show your Appreciation by rating it:
Now to try and get your files visable again, you are first going to have to see if they are marked as 'hidden' files. Click on MY COMPUTER and then on TOOLS/FOLDER OPTIONS and now on VIEW tab click on the SHOW HIDDEN FILES AND FOLDERS, now see if you can see the files/folders. If you can then what you need to do is highlight all the file/folders from that drive that you want to be able to view (select all by ctrl-a for example) then RIGHT CLICK on any file that you have just highlighted and from the menu, select PROPERTIES and now make sure that both READ ONLY and HIDDEN are NOT selected. If they are, then de-select these. Click OK and when prompted if you want to do this for all files in the sub-folders select YES, as you obviously want this action to set for all the selected files.
Once you are done, be sure to go back to the FOLDER OPTIONS and de-select the SHOW HIDDEN FILES/FOLDERS from teh view options as you do not normally want to see the hidden files/folders as these are related to the system and normal deletion of these could cause other problems. This is however, how many bad items will hide themselves, by causing normal file folders to become hidden so be sure you have performed the optimizing and various anti-spyware/malware scans.
The above mentioned solutions won't work [sorry guys but thts the truth]
May be even your Registry editor and Task manager weren't working, right?
Download this tool:
http://www.4shared.com/file/41533566/cfed03ee/Ravmon_Removal_Tool_32.html?err=no-sess
Open it, it will show a message, press 'Yes'
Then press "Restore windows default settings"
and select whichever you want to, hit apply and restart the system to see the changes.
Post a New problem for Microsoft Windows XP Professional
Email this problem
Can you Help with these Operating Systems problems?
Alguien habla espa?ol?
microsoft works trying to print...
chanies mobile TV800 not...
12 Other Users Have The Same Problem - Continued
Comment by Guest, posted on May 19, 2008
bhsrv.exe
i have the same problem
Comment by Guest, posted on May 17, 2008
my pc is not showing any hidden files and folders. i have formated it today but even after that the problem remains same. i m using nod32 antivirus.please help me i don't want to formate it again.
Comment by Guest, posted on May 16, 2008
even after untick and unselect and apply, click ok it is reverting to same problem. pl. help me in this regard, I dont want to format my system already I have done 2 times. My Xp SP2 is virus free and is running in other computers successfully.
Comment by santhoshkuma, posted on May 12, 2008
yes i having same problem
Comment by dachu, posted on Apr 29, 2008
i am the only administrator of my pc my hidden files are not visible after that.i am using windows xp ,..sp2 .. please help ............thanks
Comment by dhana31, posted on Apr 20, 2008
My pc is attacked by virus but my antivirus has removed eventhough my hidden files r not visible
