Question about Motorola Mobility RAZR V3m Cellular Phone
Motorola Razor V3m not power ON
This phone got dunk in clean water a year ago and again last week for a very short time. We dried it with an air dryer and oven heat at low and it worked ok the first time but not this last week? I found a step by step tutorial on how to take the covers off, cleaned everything with contact spray cleaner and found no problems that I could see,(no red dot under the battery) the battery charges normally on another similar motorola .
THE ONLY INDICATION THIS PHONE GIVES ME IS WHEN I PRESS THE ON/OFF RED KEY,THE WHOLE KEY PAD LIGHTS UP,IT STAY LIT AS LONG AS I PRESS ON IT BUT GOES OFF AS SOON AS I RELEASE IT? THE SCREEN ITSELF NEVER COMES ON ?
i WOULD LIKE TO KNOW WHAT NEEDS TO BE REPLACED? SO i COULD TRY DOING IT MYSELF? (I'm retired and on a limited budged)
Thank you
  • 34 Answers
It seems like a damaged chip possibly rusted or if you didn't take out the battery, severe damage to the whole phone. You might be able to get it repaired for less instead of replaced. I am not sure if you can buy new parts, but you can probably find a new one on ebay with a broken screen or something like that, and use parts from both to make a new phone(Did the same with 3 broken PSP consoles) I hope this helps. If you have a hard time with the second option, you can find guides for disassembly and reassembly online.
I really hope i have helped
C-m0n3y
Posted on Feb 25, 2008
I forgot my security code for a motorola razor v3m. How to fix?
Take the phone back to your service provider and have them reset the code back to the factory oroginal- usually "0000"- which you can later change.
Jul 21, 2009 | Motorola Mobility RAZR V3
Water damage and it will not work and there is the red button.
Yep.
I dropped my Blackberry in the toilet completely. It would not charge or turn on for 1 day.
But it worked after that.
You need to let it dry out. Give it a day or two.
You can also try taking out all the pieces and using a hair dryer.
If it doesn't work, you can always buy yourself one of those prepaid phones and just use your sim card with it until you can afford a new phone.
Good luck.
Apr 14, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Cellphonewater inmersion
you need to open the phone to clean it properly. without opening its not possible to get display work again. most probably display will work by cleaning it. otherwise you have to change the display.
Jan 01, 2009 | Motorola Mobility RAZR V3
Motorola razr problems
My razor broke about 1/2 year ago and im with verizon and they said their not making them anymore.. so i got a newer razor... I experienced the same problems and they got fixed when i got a new phone for free..
Dec 16, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorazr v3m won't charge...
Usually the batter gets fried when it comes in contact with water (I know because I dove into a pool, swam for 10 minutes, and had my phone in my pocket!).
1. Take the battery out of your phone instantly after water damage.
2. Dry your phone with a blow-dryer until thoroughly dry.
3. Dry the battery.
4. Place the battery back in the phone and press the power button.
5. If the phone turns on, good, if not continue to step 6.
6. Find a friend with a RAZR and use his/her battery in your phone.
If the other battery works purchase a new battery... and by the way... the lines on your screen WILL GO AWAY lol
Jul 22, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola RAZR V3 Cellular Phone Charges, then turns self off
when you dried it off you did not open it up and have the phone service so you should take it to a repair store and have it fully service or the firmware reflash but you may have to purchase a new one
Jul 20, 2008 | Motorola Mobility RAZR V3
Motorola razor V3m displays "no Service".
You need to take the phone to have the main-board fix to get the service up again.
Jul 04, 2008 | Motorola Mobility RAZR V3
My razor
yes, if your phone gets wet dry it out before turning it on. once dried if still not working properly take to repair shop or replace keypad yourself
Nov 20, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola RAZR V3 Cellular Problems With Water Damage
yes it is bad
getting hot means that the internals are frying or shorting out
leave the battery off of it for about a week then try it again.
I really don't like your chances of it working properly again though.
Good Luck
Nov 17, 2007 | Motorola Mobility RAZR V3
Motorola RAZR V3 drowned in river water
You didn't say how long you allowed your phone to dry after it took the swim, nor how long it was in the water. Both are important in trying to guess how much damage may have been done. If the time in the water was very short (very) then there may be hope. If you allowed the phone to dry for a long time (possibly a day or even two) then there is hope as well.
You are right to state that the water had a high turbidity. It's not actually the water that will kill it, it's the stuff in the water.
One thing to think about would be to actually take the phone apart as far down as you can (and dare depending on your skill and knowledge of getting it back together). Once you've taken it apart, rinse it a couple of times with isopropyl alcohol. Doing this may once again suspend all the "stuff" that was left when the water evaporated. and the alcohol shouldn't leave any residue. After you've rinse the phone, allow it to dry for a day or two. Yeah a day or two may sound like a long time to be without you're phone, but it doesn't work right now anyway, so err on the side of caution. Now you may be tempted to use a hair dryer, I don't recommend the hair dryer. You could actually get some components of your phone too hot and cause yourself problems. If you want to I've had good results from laying electronic components on top of a heat and air vent in the house. The heat coming out (at this time of year) should not be warm enough to cause any damage and even the cool air (in the summer) gets good air flow to the device and helps evaporate any moisture, unless of course you have really high humidity.
Anyway, I rambled some there but I hope I've helped at least a little.
Aug 25, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
26 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
