Question about Motorola Mobility RAZR V3m Cellular Phone
Pairing Jabra BT135 with motorola L2
I am unable to pair the bluetooth headset (Jabra BT135)with my Motorola L2 phone. It searches for bluetooth devices but does not recognise the headset.
The blue light on the headset blinks all the while.
Thanks in advance
Anuj
my motarola razor is having the same issue...please what an i doing wrong.
  • 4 more comments
  • techy kelli Feb 25, 2008
    thanks
  • techy kelli Feb 28, 2008
    i fixed my problem by holdin the jabar on the off postion till it went off then continued to hold until it finally went into the solid light mode then had the razor look for the device it Worked!! Now Im hands free. yea
  • filersmith Mar 04, 2008
    I am not able to pair my v3m with my Jabra BT135
  • Anonymous Apr 05, 2008
    I had the same problem, but after following the addivce from techy Kelli's, its fixed. Hold it down unitll you see the solid blue light. I did this with a different style Jabra.
  • Lynne Gray
    Lynne Gray Mar 13, 2013
    Thank you I have just wasted four hours trying until I read this :)
  • Lynne Gray
    TThank you...I spent 4 hours trying to do the same and now you hae fixed it :)
How do i re-set the phone & trhe head set?
Posted on Feb 27, 2008
  • 76 Answers
Your not doing anything wrong it usually means that the headset isn't capable with ur razr or you need to reset both of them and try it again. Hope this helps =)
Posted on Feb 25, 2008
My phone asks for headset in "discoverable mode" How do I get it there?
What kind of phone do you have? I have heard people with LG phones say that it does not pair with their phone. If this is not an issue with you then these steps may be more helpful:
1. Charge your Jabra BT135 until the solid blue LED turns off
(approximately 2 hours)
2. Make sure the Jabra BT135 is switched off
3. To put the Jabra BT135 in pairing mode, press and hold the multifunction
button until the LED stops flashing and turns solid blue
4. Set your mobile phone to "discover" the Jabra BT135 (see your phone
user guide)
5. Press Yes or OK when asked if you want to pair the phone with the
Jabra BT135
6. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK
7. Your phone will confirm when pairing is complete and your headset
will flash
Jun 17, 2011 | Jabra BT135 Bluetooth Headset
Unable to pair Jabra 5050 with Motorola qa1. Bluetooth is on in both devices, unable to find device from QA1 or from BB.
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Dec 14, 2009 | Jabra SP5050 Bluetooth Headset
I have a Jabra set, but my Motorola Krazer can not find it
Follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for around 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Jabra device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 16, 2009 | Jabra BT350 Bluetooth Headset Headset
Pairing my motorola H710 to my Blackberry Storm phone
try and remove the current bluetooth device. Close the headset. Go to thephone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Dec 30, 2008 | Motorola Mobility H710 Bluetooth Headset
Setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Dec 26, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra BT135
Firs turn it off then..........
then hold the button for 10 seconds
it will now pair with your phone
the code is "0000"
Apr 25, 2008 | Jabra Bluetooth Headset with Adjustable...
Pair with mobile phone
when you activate the Jabra put your mobile to search for the bluetooth device when it finds it then pair code is 0000....then it should be paired
Mar 07, 2008 | Motorola Mobility RAZR V3m Cellular Phone
okay, try this, turn off the jabra headset, and then, hold the power button but hold it down until the lights flash in a different way, and make ur phone search for devices and if it finds it then its all good, just use the 0000 password to pair it.if this works give me a fix rate. thank U
Feb 11, 2008 | Motorola Mobility L2 Cellular Phone
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Motorola Mobility RAZR V3m Cellular Phone Logo
347 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
