Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Phillips rear projection tv model #60pp9202/17f
I have a 3 year old phillips 60PP9202 t.v. that has red lines at the top of the screen and at the bottom a double image of the picture in red. The red and the blue converge are lined up as well as the multpoint blue. The red multipoint is okay across the middle of the screen but the top row and bottom 2 rows will not correctly line up. It shows separate red and green crosses that are slightly at an angle to each other. My husband turned the red "bulb" off and the image cleared. Can you tell me what may need to be replaced and where and how to locate it.
  • 9 more comments
  • Jimmie Gagum Mar 30, 2008
    I'm having the same issue....
  • Anonymous Apr 06, 2008
    yes i have the same problem my sitiation are vary clos the that problem can you please help me to fix it
  • ANDRES GUEVARA Apr 07, 2008
  • Anonymous Aug 20, 2008
    The red bends up in the let top corner.And leaves a blue hump in the lower left corner.
  • buddy101 Aug 20, 2008
    i have the same problem with the red and blue lines, when i go to the menu to try to adjust the crosshairs...nothing happens. they will not adjust
  • kayaking Aug 23, 2008
    very blury, double words, eyes outlined with red and blue cant even watch can this be fixed
  • saguilar247 Jan 15, 2009
    does it have to do with picture tube i have same problem
  • splitbottom Jan 25, 2009
    is the convergence problem something that a guy with some intelligence and mechanical knowledge could fix or would I be better off calling the repairman?
  • Anonymous Mar 02, 2009
    My TV is showing double vision on the screen top and bottom.
  • pumpkin_5026 Mar 15, 2009
    my 60" Philips has red and green rainbow like lines , mostly at the bottom.seems to go away for a while if I turn it off and right back on.It does not do it all the time .???
  • nicetry2001 Mar 17, 2009
    same problem
  • Philips Master
  • 3,459 Answers
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Phillips rear projection tv model #60pp9202/17f - 701cb04.jpg
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your Phillips rear projection tv model #60pp9202/17f - 2c07611.png chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 22, 2009
You turn TV on , but no pucture nor sound, only a constant beeping (like a cricket) can be heard coming from inside back panel.
Posted on May 31, 2010
  • edwin Nov 14, 2011
    I have the same issue
I had same problem, i opened up the back of tv. then i turned on the cable guide. i saw three lines blue, red, and green. under the lamp there is two washer type things with bumps. i turned them, i noticed that they moved the lines on the screen in a circular motion. after fiddling with the thing for a while, i finally got all the lines on top of each other. this made picture alot better, then i went to the little box that controls color adjustments, i made the colors to my liking and then i went to the lamps, i loosened the wing nut and turned the lamps and focussed the picture more. after this i closed up the tv, and went to my menu, and set my color convergence there. the tv pic is simply awsome, and high def channels make me feel like im there. i saved 390.00 doing this, i wasnt going to pay to repair it, cause i got it for free, and original intention was to make a place for my kids to have puppet shows in. hope this helps. lar.
Posted on Mar 14, 2009
  • 979 Answers
Convergence problems! If the mechanical set-up and electronic adjusts aren't cutting it, you may very well have to replace one or more devices on the red conv board, including but not limited to, the conv IC....accordianman
Posted on Feb 25, 2008
Why is my Phillips 60pp9202/17F making a clicking noise when trying to turn it on?
Posted on Mar 23, 2011
LINES AT THE TOP AND BOTTOM OF PHILLIPS MODEL NO. 60PP9202/17F
no lamp for this model, it uses three picture tubes but the three D looking picture is a convergence circuit problem and is fixable.
Apr 04, 2012 | Philips 60PP9202 60" Rear Projection...
I have a Phillips rear projection tv model number 60PP9202/17F.....it 60
What is the problem of your
Phillips rear projection tv model number 60PP9202/17F?
Jan 10, 2012 | Philips 60PP9202 60" Rear Projection...
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
When watching tv the images are green and red on a Phillips 60pp9202 rear projection
you have a convergence problem.
try to change the convegence output ic. stk392-120 with burnt resistors you're gonna see.
Oct 18, 2009 | Philips 60PP9202 60" Rear Projection...
Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Jul 25, 2009 | Philips 60PP9202 60" Rear Projection...
My rear projection television looks like it is 3D
replace the lamps and then run the synch routine from the main menu. unfortunitly with the expense of the lamps and the low price to replace projection tvs it might not be worthwhile to fix but just replace.
HINT wait till after new years, LCD large screen tv sold about 35% of what was expected during xmas so they will be real real cheap after the 1st of the year
Dec 29, 2008 | Philips TV Tuner Video Capture PCI Card -...
Can not line up red convergence
The convergence chips are toast. This is a common problem. Goto the site www.TvRepairKits.com to get a repair kit with instructions.
Dec 22, 2008 | Philips 60PP9202 60" Rear Projection...
No Red color on Phillips tv model 60PP9202/17F
one of the picture tubes inside the went bad you 'll need a tech
Aug 13, 2008 | Philips 60PP9202 60" Rear Projection...
Menue and multipoint
I fixed this tonight -- it was the convergence amps, which I purchased for $20. Thought it was the convergence board at first but it turned out to be the amps, which commonly fail after 3 years or so.
Dec 17, 2007 | Philips 60PP9202 60" Rear Projection...
Blue Color spots on all pictures
Call a technician, sounds like an Integrated Circuit problem and would cost you about $250.
May 07, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
3,437 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
