Question about MTX Thunder 8302 Car Audio Amplifier
Mtx ta7801 amp not working
Hi i have an mtx ta7801 amp, i let my brother use it and it quit working. i hooked it up and all the lights would work but no sound. i checked all external and internal fuses but everything was good. when i looked inside the amp i noticed around a black diode or chip was a burn area. it looked like a drip of soda got on the a chip or something. do you know where i could get my amp fixed or find a chip?
thanks derek
Depending on where you live, Car Tunes is a good place to fix it but it might cost a good amount. I have a mtx 1501XD and the same problem, lights but no sound i saw no marks inside mine however. They told me i was better off buying a new one bc it was going to cost so much to fix most likely. That was coming from a guy I know so they were just trying to **** money out of me either, he does sound for a living.
Posted on May 29, 2008
I got a mtx ta7801 amp every time I hook it up it says short even when no rca our speaker wires are attached any one have any clue as to whath is wrong
Im sure you have but check all the fuses and be sure ground/power is in the right spot, and check remote wire for cuts
Dec 17, 2010 | MTX Thunder TA7801 Car Audio Amplifier
Can you bridge 2 4 ohm kicker speakers to a mtx thunder 7801 amp?
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Nov 12, 2010 | MTX Thunder TA7801 Car Audio Amplifier
Just hooked up mtx 500d mono amp and 12 inch sub worked for a 1/2 hour then sub quite and led on top of amp just flashes.
either ur ohm load is way off ur pos n neg might be touchin or more than likely u blew u sub is it scratchy when u push in the middle of the cone ? does it push in at all?
May 14, 2010 | Car Audio & Video
The lights on my amp dont work anymore ?
Give it a ride though the dishwasher, the amp may just be dirty.
Dec 18, 2009 | MTX Thunder TA7801 Car Audio Amplifier
Mtx thunder 1500 watt amp no sound
Even if there is no visible damage, it could be that one of the transistors is blown, Use a multimeter to check the resistance of the transistors.
Apr 09, 2009 | MTX Thunder 1501D Car Audio Amplifier
Amp is a mtx 801d not sure
no you will not blow it out by hooking up both voice coils. But First before you do, what oms are they. and is your amp one oms stable? There a lot of ways you can wire double voice coil. But if you can get me that info i can send you some digrams to help you out and tell you whats best.
Oct 05, 2008 | MTX Thunder TA7801 Car Audio Amplifier
Thunder 5604
okay u will have to troubleshoo the amp.....dose the amp light up?...when u have the radio on? also check your sub wires.going to the amp....make sure the rca'sare hooked up to the radio rear out puts are the radio sub out puts...and then test your amp gain adjustment...let me know if that work's
Jun 23, 2008 | MTX Thunder5601 300W x 1 Car Amp Mono...
MTX Thunder TA81001 amp
A large capacitor between your battery and the amp may help. Your alternator is most likely strained by the amp's power consumption. If you can't get a stronger alternator or suitable capacitor, you may nbeed to replace your battery and alternator more often than normal.
Feb 29, 2008 | MTX Thunder TA7801 Car Audio Amplifier
The red light on my amp keeps coming on and it wont work
You need to check your woofers. Most likely one or both may be a) blown or at a dead short or b) the ohm rating on them may be too low. What model woofers and amp do you have??
Nov 17, 2007 | MTX Thunder TA7801 Car Audio Amplifier
MTX Thunder 8302 Car Audio Amplifier Logo
149 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
