I have a portable dvd player that can't seem to load dvds. It knows when there is no disk present, and it can see and play a cd. I blew all the dust out, and I cleaned the lens with alcohol. No change. I pulled the ribbon and its contacts look ok. The laser lights up, and the assembly goes forward,up and down a few times, the back a little, and tries again. I can hear it making little tones, but it will keep trying forever and never play. Ideas?
I was having something like you describe happening to my "Nintaus DVD"in my case the disc would spin up and play almost to its conclusion and then it would freeze I tried cleaning the lens etc nothing along those lines worked until i removed the whole tray that the lens mechanisim is retained by in my case i was then able to see the underside of the mechanisim on this model there are 2 potentiometers for alignment purposes i found out about this in a repair book anyway the 2 pots are....1 for cd and one for dvd the machine reads in binary that is zero's and ones well if the alignment gets out of whack you get freeze ups and flickering etc anyway try turning these pots with something insulated only a very small amount and test, Some dvd's have "dvd" or "cd" marked on the circuit board in my case they were not marked so it was adjust one then test,If you decide to try this make sure you earth yourself using the metal case or ideally use an anti static wrist strap the main other thing is when you adjust do it in very small increments my dvd is only a cheap one that i thought id have to throw out so far it is working fine again, Its sort of flying by the seat of your pants re the adjustment as there are no instruments at hand unless you have access to someone who does. If you try it i wish you luck, the suggestions other people have made are all valid things too re a weak diode its great if you can fix it yourself. I just re read your post if as you say the unit will play a CD ok then you only need to adjust the DVD pot
Posted on Jan 24, 2009
It usually means that the reading laser is defective, even though it lights up it doesn't mean its working. Hope this helped =)
Posted on Feb 25, 2008
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
Jul 25, 2008 | Philips PET702 Portable DVD Player
Aug 26, 2010 | Televison & Video
Aug 27, 2008 | Onkyo DV-C601 Multi-disc DVD Player
May 29, 2008 | Apex Digital ADV3800 DVD Player/VCR
Mar 01, 2008 | Shenzhen Mizuda DVD-999 DVD Player
Feb 11, 2008 | Mintek MDP-1010 Portable DVD Player
Nov 29, 2007 | Curtis DVD8017 Portable DVD Player
Nov 24, 2007 | Durabrand PDV-705 Portable DVD Player
Apr 20, 2018 | Televison & Video
365 people viewed this question
I found this at allexperts.com: The symptoms you describe are usually because the laser diode is either weak, out of alignment or the video decoder chip has gone sour.
The solution is to have it diagnosed as to which of the conditions above are the prevailing culprit.
Unfortunately, the cost of repair is almost equal or in some cases greater than the cost of a new dvd player.
The reason the cd portion is working, still, is because that function requires much lower laser diode power and the decoder algorithm is entirely different from that of a dvd disc. Therefore, one may work while the other will not.
The "No Disc" indication is because the system is not getting decoded data back from the system.
If you have bumped the player severely, that could have caused the laser optics to get badly out of alignment. Again, the alignment process requires the set to go back to the shop and the cost is almost as much as a new player.
This unit is a lower cost or promotional item from many retail chains and it seems to me the most likely problem is the laser diode becoming too weak to keep up with the demands of dvd playback. That is my best guess.
All the best,
Cleggsan
