Question about RCA Cable Modem DCM315R (11603540)
RCA Modem DCM315R
How do i enable the ethernet port to run a router
    Scholar:
  • 148 Answers
Just a bit of explanation. E0 interface is for inside network (LAN interface). E1 is for outside (ISP or WAN physical interface). Dialer1 is for PPPoE (the "actual"/logical WAN interface). The 1.0.0.13 is ISP provided static IP address for the use of the server. This configuration example is for running FTP server, which uses the standard TCP port 20 and 21.
The LAN uses 10.10.10.0 network with 255.255.255.0 subnet for both servers and workstations. All servers within the LAN use static IP address. The router is configured as DHCP server to give out IP info (IP addresses, subnet mask, DNS) to workstations that are configured as DHCP client.
Basically I suggest that you deploy NAT (Network Address Translation) and PAT (Port Address Translation) to setup your own servers behind Cisco router. The NAT is used to translate the ISP's given static IP address to your local IP address. The PAT is used to translate TCP ports (the port 20 and 21) between the two IP addresses.
When using NAT/PAT, keep in mind that the Internet-accessible servers are seen from the Internet as their NAT/PAT-ed IP address (the Public IP address) and not the local IP address (not the Private IP address). This understanding is very important when you or someone need to test connectivity to the server and/or when you need to create filter (access list or ACL for short) to allow only certain incoming traffic from the Internet and block others.
Side Note:
For more info on NAT/PAT concept, check out the following FAQ
»Cisco Forum FAQ »NAT and PAT; Introduction and Implementations
Instruments used in this illustration are pretty much standard for running your own servers. Please note that IP addresses, username, and password are changed. However, you could always modify the configuration to suit your situation.
This sample configuration assumes that you have a block of IP from ISP. There is a dedicated Public IP address for the router WAN interface (the Dialer1 interface) and another dedicated Public IP address for the server PAT IP address. If you only have a single Public IP address for both router WAN interface and server PAT IP address, there are several ways to configure the router.
One way is to use the same command as shown in sample configuration.
view plaincopy to clipboardprint?
  1. ip nat source static tcp 10.10.10.2 21 1.1.1.14 21 extendable
This one configuration way is suitable when you have static IP address from your ISP and you know exactly what the IP address is. In this case you have the 1.1.1.14 single static IP address for both the WAN interface and Public server IP address.
When you are unsure which IP address you receive from the ISP, or when your Public IP address keep changing; then another way to configure the static PAT is following
  1. ip nat source static tcp 10.10.10.2 21 interface Dialer1 21 extendable
With situation of dynamic IP address, at some point you still need to know the exact Public IP address you receive from your ISP for server connection testing and production time. To find out, you can issue show ip interface brief command on the router. You will then see the associated WAN interface Public IP address.
Posted on Feb 25, 2008
I dont know how to connect a belkin wireless router to thr rca modern router?
You will need 2 ethernet cable to set it up Tha first one will go from the ethernet port in your cable modem to the ethernet port of the router mentionned Modem. The next cable will go fron one of the port of the router to the ethernet port of your Computer,
This second cable is placed temporarely to be able to do set the routers settings,
After this is done insert the Cd that came with your Belkin router and it should guide you through the different setting pages of the router.
Jul 25, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I need connect a wirelees router a this modem,u help me plzzz
most wireless routers are setup for cable modems out of the box all you need to do is run an Ethernet cable from your modem to your wireless router. you can then access your wireless router by the ip address and a pc hooked you directly to the router.
Feb 28, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I'm trying to hookup a usb modem broadband to a router for a desktop and laptop
This wireless router does not have any USB connection on it. Types of connection available on this router are wireless and Ethernet. You can check on the modem if there is an Ethernet port on it.
If your modem has an Ethernet port, I recommend that you test the Ethernet connection using one of your computers. We want to make sure that the Ethernet connection on the modem is enabled. If not, you may need to contact your ISP or the modem manufacturer to make sure that the Ethernet will work before you install the router.
If your modem does not have have an Ethernet port on it. This is not the router that will do the work for you. And I personally does not seen any router yet with the USB port for the modem.
Feb 10, 2010 | Linksys Wireless-G Broadband Router
I have the RCA DCM425C cable modem and also Vonage phone service. So my modem ethernet connects to my Vonage internet. I would like to go wireless in my house. How would I do this?
You would connect from the output of the Vonage modem to the wireless router and then from the wireless router you can connect Ethernet to your desktop if you have one and then anything else can run off of the wireless.
or
get a wireless router / cable modem combo provided by companies such as netgear then you would connect the Vonage to the router through one of the available Ethernet ports and any other Ethernet connections to the router as well and anything else wireless would work wireless.
Nov 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
RCA Cable Modem DCM315R Problem:
Who is you service provider and do you have a router connected to it as well?
Oct 20, 2008 | RCA Cable Modem DCM315R (11603540)
How to connect to the internet with a PSP
To connect your modem to a wirless router. Then make sure when you set up the wireless router that you remember the settings (mainly the password) and what kind of security you set, WAP, WEP AES or TKTP. Also make sure the wirless connector is enabled on your PSP (basically a switch on top of your hand held system).
Jul 06, 2008 | RCA DCM315R Modem
RCA router
first, go to: 192.168.0.1
the username is blank, and the password is "admin"
go to the advance tab
click forwarding
fill in the information, and then click "enable" to the far right of it
then click "apply" at the bottom of the page
Jan 11, 2008 | RCA Cable Modem DCM315R (11603540)
Bridge RCA Thomson DCM315R
Usually cable providers provide public ip directly to your company ( already bridged ). so no need to configure your modem to bridge.
- Connect the computer directly to the modem and if possible, let me know the ip address of your PC, So we can find the modem already bridged.
- If its already bridged, then Open the ports on your Router ( port number : 3389 for TCP ) or else you may try DMZ Host on your router to check whether it works.
Note:
DMZ ( Demilitarize Zone ) host which opens all ports on your network and shows ur computer to the outside Network which is not really secured one. but you can try it for testing purpose whether it let you to use remote desktop.
Hope this will help you
Sep 19, 2007 | RCA Cable Modem DCM315R (11603540)
RCA Cable Modem DCM315R (11603540) Logo
2,069 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
shaun taylor
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
