have you checked the remote terminal for voltage? Where is the 12v remote terminal wired from (normally from the elec aerial on the radio or ignition 12v)have you checked the remote terminal for voltage? Where is the 12v remote terminal wired from (normally from the elec aerial on the radio or ignition 12v)
You can't post conmments that contain an email address.
Where is your ground located?
It never hurts to put a beefy ground on an amp. If you do have it grounded take the bolt out use a wire brush on the bolt and on the surface you are grounding to.
Also check our remote wire(blue). The purpose of this wire it shuts your amp down and turns it on when you turn on the head unit.
Ssometimes the antenna wire is not enough to turn on the amp , some cars use relays in thier power antenna turn on set up which require low 500 ma 's . hit the amps turn on post with 12 volts directly from a jumper wire with alligator clips from main poower wire , if it still wont tunr on the amp the amp may be faulty , also check amps ground , metal its grounded must be free of paint , undercoating rug ect ....
The T-stat is broken & needs replacement. Most Mfgs have exploded views of equipment listed on their websites & this is an easy fix if you have more than basic mechanical skills. 1st & foremost, find the breaker panel & turn the breaker for the oven OFF before attempting any repair. Parts can be located either on Tappan's website or a local appliance parts house.
