Question about Kenmore Elite HE4 Electric Dryer
My dryer won't start!
I bought my dryer two years ago and for the past four months has been erratic. I wont start when I push the start button, actually I get nothing! The light in the dryer is on when I open the door, so I no its not the outlet. Then the next day I push the start button and it works. Most days I just hit the control panel then pull on it towards me until it finally registers something. Sometimes it only lets me do one certain cycle, which ever one it picks. This is soo frustrating!! Can I remove the front panel and see if there is a wiring problem? What should I do? Please somebody help!!
  • kerabare Mar 12, 2008
    Where is the battery for my dryer? Thank you by the way.
    Sergeant:
    Champion:
  • 281 Answers
The battery in your dryer is actually not working very well. I suggest you to change it because when the electronics pass the 2 years they start not working very well. Hope this helped you.
Posted on Feb 25, 2008
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
I bought it 10 years ago but I used only once or twice. I went to used it but when pushing the start button it won't star
i would make sure batteries are good an with the batteries out look inside compartment and see if there any rust down where the batteries go if so try to scrape them clean
Aug 05, 2012 | Omron HEM-712CN2 cuff blood pressure...
Maytag Dryer - When pushing the button, it wants to turn on but wont. While my finger is on the 'On' button, the dryer will try to turn on but when I remove my finger, it gives up. The drum...
it's still under warranty for one year,call the factory and they should send someone out to look at it for you.don't touch it,if they can tell someone touched it you can void the warranty
Oct 10, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
My Kenmore elite gas dryer buzzes and does not turn on. It has done this in the past, but then a few minutes later would start. (Almost like it was overheated). It has done this occasionally since we...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2011 | Kenmore Dryers
Dryer won't start when start button is pushed.
you might want to check the door switch , its possible when the door switch is open the unit will not start
Aug 04, 2011 | Whirlpool Inglis IP8200 Dryer
Whirlpool dryer model number WED5300SQ0 wont start
take a meter and check door switch then if good take the back off and check all thermostats,thermal fuse,AND if your belt is off theres a safety switch on the idler pully.hope this helps
Nov 15, 2009 | Whirlpool WED5300S Electric Dryer
Put clothes in, set the timer, push the start button and it makes a hum like it is trying to start but does not start and then there is a funny smell coming from the dryer. Is the motor burning/burned up...
it could be the belt slipping,the motor going bad, the motor start cap going out the drum bearing or motor bearings dried out causing over heating of unit causing electrical smell, hard to give a ball-park,anywhere from $50 to $300 for repairs depending parts required and labor/time
Oct 28, 2009 | Amana DLE330RAW Electric Dryer
Model 11060052991 kenmore elite dryer
For heat issue I had replaced the heat relay switch a year ago and that worked. For the start button holding issue I replaced the motor relay switch and the dryer is fine again.
Nov 25, 2007 | Kenmore 63942 Dryer
Kenmore elite he3 electric dryer
If you get a series of four rapid beeps when you push START in an attempt to start your dryer, your door switch (interlock) is defective.  I have experienced this problem before and it is a fairly simple problem to fix.  The easiest way to tell is to open the dryer door and push the door interlock in by hand.  Hold it in while pushing the START button.  If the dryer starts, then all you have is a simple problem of the door not closing properly.  If the dryer still does not start, however, replace the dryer door interlock.  The interlock should also make a definite "click" while pushing it in.  If it does not, the switch is worn out.  Some dryers have an upper and lower door interlock.  If yours is equipped with two interlocks, make sure they are both functioning and that the door is latched properly.  I have experienced problems where dryers doors with two interlocks would close at the top, but not at the bottom.  The dryer would not start as a result.  If you can provide me with your model number I can get a part number and price for you.  I can also tell you where you can get the part and provide instructions on how to replace it.  Let me know.  I hope this helps you.
Oct 31, 2007 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
64 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
