Question about Compaq Presario SR1050NX (DW257A) PC Desktop
Replacing video card
It doesnt look as if the old card comes out. does the old one stay in and put in the new one?
    Novelist:
    Champion:
  • 233 Answers
Sounds like your graphics are built into the motherboard. Add new card & attach the monitor to the new card. If the computer boots, go into device manager in Windows and disable the on-board graphics.
Posted on Dec 15, 2008
Compaq sr2010nx
moniter dont come on, already replaced motherboard
Posted on Jul 13, 2008
    Genius:
  • 3,587 Answers
Hmmm..old card should just remove with one screw along back panel, unless it's the embedded version
go to control panel, system, device manager, and let me know what it says under audio devices.
Posted on Feb 25, 2008
My hp a362n doesnt want to boot.
your problem is not clear it's not booting or not comming display ?
Jan 07, 2012 | HP Computers & Internet
My monitor will not turn on.
To determine if the problem is the monitor or the video card you need to unplug the video cable from the monitor so that it is not getting any signal from computer. Then try the menu buttons on the front of the monitor to determine if you can see the menu come up. If the menu appears it means the boards and LCD is functioning properly and that the issue is with the video source or cable. If it doesnt it means that the LCD is bad. These are backlt LCD's, meaning they use a light behind the actual picture so that it controls the brightness. Think of an old slide projector or light through a stained glass window. If the backlight is out its not worth fixing and you should consider purchasing a new monitor. This model often does have a backlight burn out after a few year service. They are not as durable as the old CRT monitors. If you do see the MENU then you need to test other options. If you can obtain a different cable and the one you are using is detachable from the monitor then try a new cable. If you still dont get any picture at this point it is safe to assume your video output is bad. Not sure which computer you have, but usually in todays computers the video card is part of the motherboard and not seperate. If yours is seperate you can try reseating it in teh PCI slot. You will need to open your computer case for this. Google PCI slot for your model and then images, it will show you what area to look. You cant replace the video card ON the motherboard if its there... but you can put a NEW one in via the PCI slot. Video cards range in price and if the computer didnt give you any issues I would start with another monitor from a friend to verify video card works or doesnt before replacing. Im 90% sure this is the monitor based on your statement and 10% possible video card.
Jun 28, 2010 | HP Pavilion F1703 17" LCD Monitor
I have a sony vaio pc with a p 450-vx mother board, the darn thing won't boot up the mother board light is on and the fans come on light on front is amber. Oh yeah I,ve changed out video cards.
if the screen comes on for a few seconds and then goes to sleep mode you probably have not installed the drivers for the new video card correctly. you should shut down computer, replace the new card with the old one, put in the disk with the drivers for the new card, install the new drivers and then shutdn and replace the old with the new and reboot. this should solve the problem. please rate me and thanks for choosing enterprise computing solutions..
Sep 30, 2009 | Computers & Internet
My micro sd card doesnt work
probably your memory card has had it...if it will let you reformat it, re-install flash card drivers and chuck a few games on and see what happens...also check inside card slot and make sure all the contact pins look nice and straight. if you can also just try a new memory card in the meantime to put your mind at rest concerning the problem coming from the ds...highly unlikely.
Aug 02, 2009 | Nintendo DS Lite Console
I bought a video card 8J329, it doesnt match orig. mount
There are 3 types of "mounts" to put your video card in. PCI-express is the newest and fastest, AGP is the 2nd and PCI coming in last. None of them are interchangeable. If your new card doesnt match up to the slot available on your motherboard, then you will have to either return your card, or replace your motherboard, which woul likely include replacing your processor and ram, so if at all possible, see if you can exchange your card.
Check out this picture to see which slot you have.
http://www.diamondmm.com/images/bustypedrwng.gif
Jul 06, 2009 | Dell (8J329), (16 MB) Graphic Card
Micro Sd card not working
try getting a new sd card
Mar 25, 2009 | Nintendo DS Console
Video Card
It is likely to be your old graphics drivers conflicting with the new card - Put the old card back in and be sure to remove them
1. Start
2. Right Click My Computer
3. Properties
4. Hardware Tab
5. Device Manager
6. Display Adapter
7. Uninstall
Turn your PC off and place the new card in then reboot
Install the new drivers after booting.
If this helped dont forget to rate me ;)
Blazamane
Jan 08, 2009 | Dell Dimension 4700 PC Desktop
On board video...
The BIOS will most likely be set to auto detect, when you physically install the new card the BIOS should detect it and auto disable the onboard video.
Aug 02, 2008 | Dell Dimension 3000 PC Desktop
Compaq Presario SR1050NX (DW257A) PC Desktop Logo
123 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
