Question about Dell 1600n All-In-One Laser Printer
Add paper message
I am getting this message and i can't get rid of it, the tray is fully loaded, any comments on how to solve it?
  • diazklm Feb 25, 2008
    Thank you for the advise, will try as soon as i get a repair manual in my hands.
  • gawafa Mar 18, 2008
    My printer Dell 1600n is full of paper and whenever i try to print from my desktop always fails and the error msg appears to me is ADD papper although it is full of pappers
    Problem Solver:
You will be glad to know, this is not your printer's fault. We went round and round with dell support when we first got 150 dell 1600n's. We sent in copies of documents that were causing the problem. Finally, they figured it out for us. Embedded in the document was junk that was telling the printer to pull from tray2. All you have to do to fix the problem, is take the word document, go into file, page setup. on paper tab, select default tray for first page, default tray for all other pages, and apply to whole document. to clear the message, you will have to delete the print job from the queue, and turn off the printer, then turn back on, and you should be set. The message add paper, is really what the printer should be telling you, except that it should add to tray2, so you know it is trying to pull paper from the manual sheetfeed port on the front.(you could add paper there, till the document finishes printing, but our docs are hundreds of pages, so that is not practical. Barry Smoke Network Administrator AR Division of Legislative Audit
Posted on May 03, 2008
  • 152 Answers
Paper tray sensor not working check sensor cable and service
sensor unit and service also plunzer assy
Posted on Feb 25, 2008
My Kyocera KM-1635 attention light is red and when I press the printer button the message says "add paper - oficio 2"
it sounds like the job is asking for that size paper delete the job or load the paper its asking for
Apr 03, 2018 | Kyocera Office Equipment & Supplies
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
We have messages in the memory but keep getting message to 'load Paper' there is paper in the machine . I hvae tried putting fresh paper in , but it comes up with the same load paper message?
first thing is you have to insert new A4 sheet in to the rec/paper tray.then press the STOP key.after machine try to feed the paper in to the printer unit and you can get print.( if the machine cant feet the paper,the machine have some paper feeding problem and you have to get technical support to solve this problem)
Mar 07, 2011 | Canon L220 Plain Paper Laser Fax
I am getting error message ' Load Tray 1, 024-910, Printer' but there is paper inside. Once we open tray and close, error message dissapears. Regards Melane
Make sure that after you add paper, that you tell the printer the right size paper. Chances are you accidently changed the paper size and the printer is letting you know that the "wrong" paper is in the tray. If you are using standard printer paper, be sure to change the paper settings back to "Letter"
Dec 08, 2010 | Dell 5110cn Laser Printer
Paper tray
You're not providing much in the way of information here...all copiers have a sensor for each paper tray that signals the copier they have paper available to perform the necessary function. The sensor(s) could just be dirty and need to be cleaned. Check the paper tray to make sure the paper is loaded correctly, meaning if the tray has a bottom that lifts up as the paper is used, kind of like a spring mechanism, the sensor in question could be located there.
If my answer doesn't provide enough detail for you, please add a comment with the make and model number of the sopier, which paper tray is having the problem and whether or not other paper trays are acting up; also please post how long this problem has been occurring and whether or not the copier is "new" (less than six months old) or not.
Oct 08, 2009 | Office Equipment & Supplies
Error message on 4050n printer "manually feed hp tough letter"
What error message is on the display?
To solve one common problem, try this: Take out the paper tray. Slide the blue fence at the back away from the paper (toward the back of the tray) then slide it back to the correct position for the size of the paper. Replace the paper tray and see if the error message still appears.
Jan 20, 2009 | HP LaserJet 4050n Printer
HP LaserJet 2430dtn - "Tray 2 open or empty"
1-Is the paper set correctly in the tray? if you have Letter paper in it make sure the guides are snug against it
2-Check the lever inside the tray, remove the tray and look at the tires there should be a lever that you ca move freely that is the paper sensor
Oct 10, 2008 | HP LaserJet 2430dtn Printer
HP Officejet 7410 AIO keeps saying out of paper when plenty of paper loaded
Once remove both the trays and insert them again and if the problem persists, power cycle and semi-full reset the all-in-one.
May 27, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Loading paper
is the tray going up when you put the paper in and close it? is the sensor there? there has to be a lever that is free floating in the tray, when you put paper it goes up and shows has paper, when out it goes down for add paper.
Jan 14, 2008 | Canon FAX-L1000 Plain Paper Laser
Dell 1600n All-In-One Laser Printer Logo
472 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
